Old 11-02-2008, 11:58 AM   #1
RPinoski1
Default Re: GT class configuration...
Just pick what ever GT class you want to run and multiply the hp to the class you choose. With the ability to adjust the shipping weight in GT the door is wide open to put a combo where it will be competitive.
RPinoski1 is offline   Reply With Quote
Old 11-02-2008, 02:50 PM   #2
trmnatr
To the original poster, I dont mean to jump in on the thread but i have the same question
With a heavy car, Which GT class would a 327/275 or 327/300 fall under with an automatic?
trmnatr is offline   Reply With Quote
Old 11-02-2008, 03:21 PM   #3
Adger Smith
Liked 880 Times in 311 Posts
Looks like the 327 275 has been gifted with HP. (NHRA.com) The 1966 275 is now at 299 HP with OE heads & 304 HP w replacement heads. The 327 300 HP is at 285 w OE heads & 290 W Replacement heads. Might make the 300 a better choice, depending on the differences in the engine combos. If you know the shipping weight of the heavy car you want to use you can use Bill's GT calculator to figure out what classes it will fit. You have to know 3 things to figure the class w/GT calculator. 1. Shipping weight of the car you want to use. You can get the factory shipping weight from the NHRA classification guide. http://www.nhra.com/tech_specs/classification/ 2. The factored HP of the engine. (get the same place) 3. Either Auto or Man. The program works. It even gives you choices of which classes you can move to by adding or subtracting weight & the HP required to run. Pretty nice tool.
Adger Smith (Former SS)
Old 11-19-2014, 11:17 PM   #4
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Adger that 327/275/299 is the stick hp. Been at that hp for several years. I ran that combo 2006 to 2012.
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
