Liked 166 Times in 46 Posts
Liked 591 Times in 102 Posts
The DQ on the one qualifying sheet was a tower clerical error. He passed fuel check on the initial qualifying runs, had an issue in the class run.
Julie Jordan 7549 STK |
i agree with the fuel check how bogus can this fuel really be? even when vp is the official fuel of nhra. ive had all kinds of issues with vp c12. i like the fuel it works good but if it does not pass its no good to me . thats why i switched and have not had any problems since. and it is cheaper and runs the same.
I`ve never had a problem with Sunoco Purple,even after sitting in the tank all winter.
Lane Weber It`s Not What You Drive That Wins....It`s How You Drive It |
We have had some very slight issues with C-12. Neither car has been tossed, but we have been told it read marginal. Normally, adding some fresh C-12 resolves the issue. Each time it has happened we've been told that it has gone somewhat "stale" from being exposed to the atmosphere (in a vented fuel cell between races mostly). We now usually drain both cells down to about what we need to load the cars and unload them later. Then we just add fresh C-12 before time trials. I guess C-12 is somewhat sensitive. But I like the results I get with it, so long as I don't have worse issues, or need more octane, we'll stick with it.
Alan Roehrich 212A G/S |
Liked 7 Times in 5 Posts
Has anyone ever smelled bad gas?
Liked 282 Times in 103 Posts
Liked 57 Times in 14 Posts
With regard to the people who have already replied to this thread: What engines do you guys run? I know the C-11 is better than C-12 for our small block (more power on dyno), and it burns cleaner. Never have had a problem with C-11, and we start the year with what's left in the trailer. It usually sits awhile and goes through the winter outside.
Mike Voth 5189 GTN - 5188 GTO Voth Racing |
Liked 535 Times in 86 Posts
Byron, Dad and I all run Sunoco purple. I only remember 1 time we had an issue and that was Dad at E'town this year........but Byron and I both passed!!! Same fuel, same drum! You figure that one out???? They blamed it on the car???
Liked 104 Times in 35 Posts
Shreveport Points meet last month after 2nd round stock.I pulled C-12.. Gave to fuel check, it FAILED.. Go back and get another it Failed. Waited for about 12 racers to go thru.. 3rd time C-12 PASSED with flying Colors.. Go figure
Bobby Brannon 4705 STK, SS |
