Old 10-09-2008, 12:37 PM   #1
SC183
Send a message via AIM to SC183
Default Re: State Police Fatal Accident Unit Releases Findings on Drag Strip Crash that Claim
Ethanol, also called ethyl alcohol, pure alcohol, grain alcohol, or drinking alcohol, is a volatile, flammable, colorless liquid. It is a psychoactive drug, best known as the type of alcohol found in alcoholic beverages and in thermometers. In common usage, it is often referred to simply as alcohol.
Ethanol is abbreviated as EtOH, using the common organic chemistry notation of representing the ethyl group (C2H5) with Et. This designation is used both by EMS and Hospital ER staff when describing alcohol intoxication, and is found in most chemistry textbooks as well.
Methanol, also known as methyl alcohol, carbinol, wood alcohol, wood naphtha or wood spirits, is a chemical compound with chemical formula CH3OH (often abbreviated MeOH).
Methanol is often called wood alcohol because it was once produced chiefly as a byproduct of the destructive distillation of wood. It is now produced synthetically by a multi-step process: natural gas or coal gas and steam are reformed in a furnace to produce hydrogen and carbon monoxide; then, hydrogen and carbon monoxide gases react under pressure in the presence of a catalyst.
Because of its poisonous properties, methanol is frequently used as a denaturant additive for ethanol manufactured for industrial uses— this addition of a poison economically exempts industrial ethanol from the rather significant 'liquor' taxes that would otherwise be levied as it is the essence of all potable alcoholic beverages
SC183 is offline   Reply With Quote
Old 10-09-2008, 12:45 PM   #2
mcaruso
mcaruso's Avatar
....I think I need a drink after reading this.
Marc Caruso
S/G 132
S/C C132
mcaruso is offline   Reply With Quote
Old 10-09-2008, 12:50 PM   #3
SC183
Although now we mix ethanol with gasoline to make E85,so I wonder when the government will start charging the liquor tax on E85.
