Old 09-24-2008, 10:58 PM   #1
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Thumbs down Re: NMCA pictures
OMG! Why would you do this over and over again until you destroy that beautiful car and yourself? I don't understand. Jim
Old 09-25-2008, 05:59 PM   #2
gymracer01
Default Re: NMCA pictures
Jim, I don't know what their deal was this weekend. They usually have it under control. I guess they thought they had the hit soften up for the second run. Like I said I didn't get by to talk to them after. I was too busy going -.009 red and losing a bye to the final. John is a good racer, he must have had something going one.
Jim N.
gymracer01 is offline   Reply With Quote
Old 10-01-2008, 06:28 AM   #3
John Langer
Liked 3 Times in 1 Post
I have been racing that car since 1994. I have made thousands of passes, held national records and won world championships with it. During that time it has only done that 4 times. Two times that weekend, once last year at the same track durng the first round of eliminations and once 4 years ago at North East Dragway in NC. Those that are unfamiliar with the nmca, the class I race in is called Pro Stock. It is a heads up weight per cubic inch class with strict chassis, tire and engine limitations. These cars are max effort from the engines to the pro-flite trans to the dewco rears. We are not allowed to use wheelie bars, traction control devices or mercury switchs to pull timing during wheel stands. The top 8 qualifiers are usually within .06 seconds. My car has been as fast as 1.221 60' weighing 3380lbs. Everyone is set on kill. Unfortunately a few cars have been lost over the years and a few people have gottten hurt but when we pull up to the starting line, we all know the risks. The engine in my car is a n/a traditional Pontiac 525" motor with a cast intake and single 4 carb. It makes 1117 hp and 817 ft/lbs. We are restricted to ladder bars, stock front and rear frame rails and a 29.5 x 10.5 tire. After the first wheel stand at Commerce (which I wasn't too happy about) I made major adjustments to the car. I went from 15 on the front shocks to 38 (full tight), put 2 sweeps in the rear shocks and increased the rear tire pressure 1/2 lb. I was expectiing to go up there and spin pretty bad. The second wheel stand was more violent then the first. I was in high gear by .8 seconds into the run to try to bring it down. The car was on the rear valvance before it past the tree. I am not a big fan or no wheelie bar racing but that is the class I have chosen. The series has been very good to me financially and sponsor/exposure wise. I will continue to run in that class.
John Langer is offline   Reply With Quote
Old 10-01-2008, 12:37 PM   #4
Jim Wahl
Jim Wahl's Avatar
Wink Re: NMCA pictures
John,
Thank you for the detailed explanation. I now understand your "fight control". You have a beautiful car, I hope it stays that way. Jim
Old 10-09-2008, 04:13 PM   #5
Lynn A McCarty
Lynn A McCarty's Avatar
yikes!
Lynn A McCarty 3470 SS
Lynn A McCarty is offline   Reply With Quote
Old 10-09-2008, 06:04 PM   #6
Jeff Lee
Jeff Lee's Avatar
What are the specs on that tire, section width, roll-out, diameter & width?
Jeff Lee 7494 D/S '70 AMX
Old 10-09-2008, 09:36 PM   #7
SSDiv6
Liked 1,583 Times in 582 Posts
29.5 x 10.5
Old 10-10-2008, 11:14 AM   #8
Lynn A McCarty
Originally Posted by 1664SSJA View Post
Are front end limiters allowed? Would they help at ALL with your kind of car?
Mark
If you watch that film clip, you will notice that there is very little front end travel.
Old 10-14-2008, 10:20 AM   #9
John Langer
The tires have around 94" roll out and have a tread width of around 10.2"
Old 10-14-2008, 10:38 PM   #10
Raceready
John,if you don't mind tellin'.What intake are you running.?
Raceready is offline   Reply With Quote
