Old 08-08-2008, 04:54 PM   #1
aspen7709
Default 440 bracket S/ST engine
440 ci iron block 66 date code HP2
forged steel crank
BME aluminum rods& total seal rings 12.5 to 1 compression
BHJ balancer SFI
Casale single idler gear drive
Crower .600+ lift solid roller cam and Crane Gold rockers
fully ported 906 heads with triple valve springs and moly retainers with lash caps and ARP studs
moroso valve covers
M1 mopar single plane intake for 4500 series carb.
Keith Black dual line oil pump and Moroso baffled Dragster/Chassis car aluminum dual pick up oil pan (NO lines or filter system)
In exxcellent shape just checked bearings and comp.This ran 9.70s in a 2900lb door car.
the block is also milled and ground for weight (no motor ears!) this has to go in a dragster or a motor plated door car!
Would make an Excellent S/ST motor or good back up S/g motor.
must sell! Am changing combo in car $4500.00 obo pictures available on request
pan and intake off for inspection. also have a 1050 dominator available at additional cost.
e-mail aspen7709@hotmail.com thanx for looking, Kenny
aspen7709 is offline   Reply With Quote
Search this Thread:
Advanced Search
