Old 08-07-2008, 12:44 PM   #1
SC1448
Liked 2 Times in 2 Posts
Cool Re: msd ignition
Try disconnecting the Tachometer (green wire) and see if that helps. Been there, done that.
-Don
SC1448 is offline   Reply With Quote
Old 08-07-2008, 02:34 PM   #2
Johnny U
Smile Re: msd ignition
No Mike, he has not fixed the problem yet but he ordered the shielded cable and is going to try that first. Thanks for the many replies.
Johnny U is offline   Reply With Quote
Old 08-07-2008, 05:55 PM   #3
thewrench3
Default Re: msd ignition
What spark plug gap are you running? Mine did that when the plugs were gapped too wide. Its something simple and easy to check.
thewrench3 is offline   Reply With Quote
Old 08-07-2008, 07:37 PM   #4
Lou SG2340
Had a simular problem several years ago, tried everything. Replaced the delay box and every thing was fine. Who knows what causes it. It should be rf from some where. I know run a msd noise filter on the ing box.
Lou SG2340 is offline   Reply With Quote
Old 08-08-2008, 11:55 PM   #5
THE LEGEND
Had a tach on my stocker did that one time.
Had a crack in my blocke shooting water on a plug do that in my Hot Rod car one time.
A friend once said you will find a 100 things wrong but only one will fix it. I wanted to smack him.LOL
Chip
THE LEGEND is offline   Reply With Quote
Old 08-09-2008, 03:19 PM   #6
348
348's Avatar
Either borrow or buy an MSD tester and hook it up in place of the cranktrigger. This way you can simulate a full run without starting the engine.Have the driver get in with all his gear on and make a simulated run.In my case I found out when I would turn the wheel slightly the wires for the line lock would touch momentaerly and activate the chip for the burnout. Plus this gives you the ability to rerout wires temperarly to see if it cures your problem or not.
Bill
Bill Hurst
S/C348H
ET348H
348 is offline   Reply With Quote
Old 08-15-2008, 09:18 PM   #7
Johnny U
Wink Re: msd ignition
Have installed shielded wires and I think he also put a bigger vent on the fuel cell, only had a #6 vent. Going to the track tomorrow to test if it doesnt RAIN again. We have had record rain this summer, wiped out alot of races so far this year. Once again thanks for all the ideas, will keep you all posted.
Old 11-29-2008, 03:29 AM   #8
sst1988
sst1988's Avatar
Chip
glenn ferguson dad told me the same thing onetime..lol.
sst1988 is offline   Reply With Quote
Old 11-29-2008, 01:36 PM   #9
Jeff Kundratic
You said that he is running a pro billet mag pickup distributor. Would you also be running alky for fuel and would you know if the distributor was changed to the lock-up position?
Jeff Kundratic is offline   Reply With Quote
