Old 08-29-2025, 12:06 PM   #1
Liked 17,515 Times in 1,595 Posts
Default Tear Down B/S ... must read
Hey guys, a post I did not want to make. Dan Williams in his B/S 69 Nova was DQ'd from the race for a carb infraction, having two holes drilled in the secondary plates. The holes are drilled for idle quality, but NHRA says that is illegal.
I thought that rule was gone years ago. With Quick Fuel carbs be legal along with swapping out boosters on the older Holley carbs. I was shocked Dan was DQ'd. And for anyone to say booster swaps are not allowed, you would be wrong. I replaced the boosters on my Mustang when I ran the 735 Holley and they were deemed legal by NHRA.
I would think a booster swap would be a performance gain, not two small holes in the secondary throttle plates... go figure.
The real kicker hear is Dan has been torn down many times, the last time was 2019 here at Indy with the same carb and NHRA had no issues with it. These guys come all the way here from England to support NHRA and get bounced for a rule that should have been taken off the books years ago.
Its really sad that rules are not updated for consistency. Aftermarket carbs, other mods to the carbs are okay, but not to small holes that give no performance gain.
I applaud NHRA for tear down, there is four stockers with the heads coming off and dozens of Stock and Super Stockers getting Carbs and throttle bodies checked along with fuel injected cars have to give access to there ecu data... but come on, getting bounced for two small holes in the carbs, so disappointing.
Old 08-29-2025, 12:11 PM   #2
Dave Casey
Liked 804 Times in 168 Posts
Default Re: Tear Down B/S ... must read
I know of one super stock racer that was dq'd for the exact same thing a year or 2 ago
Dave Casey 1330 STK
Old 08-29-2025, 12:51 PM   #3
ron mattson
Liked 69 Times in 32 Posts
My guess is that it is because the holes are on the ?secondary? side, I was told
In Chicago in 2018 no 4 corner idle even though my
Quick fuel carb came with it NHRA approved and all. I had to JB weld the secondary
Adjustment screws so they were non adjustable.
Ron Mattson 5015 STK
ron mattson is offline   Reply With Quote
Old 08-29-2025, 01:04 PM   #4
MR DERBY CITY
Liked 8,213 Times in 1,536 Posts
Bummer for sure. Love the brothers from England !!!
Old 08-29-2025, 01:16 PM   #5
Steve Stasko
Liked 291 Times in 147 Posts
I don't understand this post. The rulebook clearly states the holes may be drilled in the PRIMARY plates, other modifications prohibited.
Name:	Screenshot 2025-08-29 130745.jpg
Old 08-29-2025, 02:55 PM   #6
James Perrone
Liked 1,863 Times in 435 Posts
Depends on who?s looking at things
james perrone 1290 STK
Old 08-29-2025, 03:09 PM   #7
Mark Lewis
Liked 209 Times in 46 Posts
Apparently now you can decide if you want to teardown or not
Mark Lewis is offline   Reply With Quote
Old 08-29-2025, 03:31 PM   #8
JP1738
JP1738's Avatar
Liked 1,315 Times in 359 Posts
How's that?!
Dawson Pauley
#2827 N/SA 1980 Malibu SW 2S 305/180
#2827 S/ST 1978 Mazda RX7 w/ 383 sbc/glide
JP1738 is offline   Reply With Quote
Old 08-29-2025, 04:11 PM   #9
GTS340
Liked 1,355 Times in 414 Posts
Not much idling going on with the secondaries.Not sure why you would do so.
Paul H
Old 08-29-2025, 04:54 PM   #10
GUMP
If a guy was trying to manage his AHFS, could he disconnect the secondaries and use this to control ET?
Daren Poole-Adams
NHRA Stock/SS 2007
