Bob, I'm glad that you responded here. I started this thread in responce to yours, as I cannot post there. As I said, I prefere 1/8 mile racing, and if I were to have a chance to race it again, I would buy another Ultra third member with 5.29s or 5.43s to replace my 4.29s. I can see why some don't like running the shorter race, if they don't have the gear to mandate a shift. If you were bracket racing, I suppose it doesn't make any difference, but if you want to be on top of the game, you need to gear for it.
Just my $.02
1964 GTO 2750# 606" IA Pontiac 8.2550@164.17-1/4 1.1981-60" 5.2901@131.97-1/8 |
WD you have a PM
#3 | |
![]() I know, who looks at that when you are focused on the 1/4.... ![]() |
I look at all of the increments and break them down......60ft ---330---1/8--MPH &ET----1000---And 1/4..................I don't store 1/8 mi in the weather station because those times are 7.10 +or - running on a 6.95 dial some thing needs to change. I can take time out of the throttle stop but I have no info and rather than spend 500. to 1000. to go to a div race for test and tune/practice you stay home. Am I getting through, I don't have one of those 150+mph S/ST cars. And as you said Dave, I do have a brick I'm pushing down the track............
I run Super Pro at a 1/8 mile track in Portland, OR when I bracket race,also at Seattle and Woodburn, OR but they are 1/4 mile. I also run S/ST at all the division races and Natl opens. I really don't have a preference. Portland does it for curfew reasons so they can get the program in. Many of the tracks will switch to 1/8 mile if they have a rain delay that threatens the program. As for running S/ST S/G and S/C on 1/8 mile it isn't a big deal, I run around 7.20's when I am chasing 10.90 in the 1/4. they talked about the Natl Open in Portland being 1/8 mile so I took a stab at in the bracket race, took about 3 passes to hit it consistently. Give it a chance, don't avoid it just because it is 1/8 mile.
2 cents from the West Coast. Jim
Jim Glenn 601A |
Liked 54 Times in 33 Posts
Changing the gear when you have a large stroke engine like yours won't gain ET. The engine doesn't know it's running 1/8th mile and you run the risk of making the launch unmagaeable. However you will accelerate engine wear. Small blocks are a differnet story altogether, which is where this myth came from.
#7 | |
#8 | |
![]() By the way, Bruce, my rear bumper is the same one that I ordered from you, years ago.
1964 GTO 2750# 606" IA Pontiac 8.2550@164.17-1/4 1.1981-60" 5.2901@131.97-1/8 Last edited by WDCreech; 06-28-2008 at 01:54 AM. |
#9 | |
In all of the testing I've done with strokes of 4.21 or more, trying to short gear them for 1/8th mile wasn't worth the effort of changing gears. If your car hooks well with a short gear, well, that's good. Some guys don't have as good a chassis to work with. And the added stress isn't worth it either. Are you seeing a tenth in 1/8th mile change by short gearing? |
#10 | |
