#1 | |
Liked 24 Times in 11 Posts
Liked 346 Times in 187 Posts
Yac they should be on the NHRA Accepted Products List (if there are any currently accepted), NHRAracer.com on left, under TECH heading, Accepted Products List...Scrolled the list contents and only found Stk/SS Accepted bellhousings 3 there and all GM and all were JW Transmission and all on Pg 54. No heading there for Accepted Adapters so a call to the tech department may be in order.
Or, call JW Transmission, tell them what you want to (adapt or matchup), and they certainly know how to get it added to the list.
Gary Lucier - 7832 STK. / 7832 E.T. EF/S Slow Sled. I am, but a simple test of your true patience. So, do all the really "Big Wheelies" you can! Last edited by Cglrcng; 06-18-2025 at 06:08 PM. Reason: Additions |
Liked 1,104 Times in 302 Posts
Since it appears that a Toyota is allowed to use a GM automatic transmission, because supposedly, at some point some BMWs had GM transmissions, I wonder now if Fords will be allowed to use an adapter for a Turbo 200, since in the early 50s, Lincolns were available with a GM Hydramatic . Or is such a thing only allowed on vehicles that don`t exist in the Classification Guide?
Liked 223 Times in 73 Posts
Rory the way I see how the Toyota got a gm trans. Ford should be able to also. Ford owned jaguar for several years, jaguar's did use gm transmission for several years. This is not different then what was just approved by nhra. Ford should be able to use any GM trans, have adapters made and have them approved or bellhousing for the 200.
James Boyce 6052 K/SA Stock National record holder 2015,2018,2 times in 2022,2023 |
#5 | |
Liked 776 Times in 199 Posts
Bret Velde 2003 I/SA |
Bret I am right there with you none of my junk makes enough power to hurt a C4. Wouldn't give it up. I don't have enough money for anything that has enough power to hurt a C4
#7 | |
Liked 393 Times in 153 Posts
(which is funny as I just had it rebuilt at the tranny shop because it was trashed, lol! (not by me or my power though)
Jim Miller 103 U/SA |
#8 | |
Liked 172 Times in 81 Posts
Jim Mantle U/V/SA 6632 |
Liked 2,486 Times in 697 Posts
I wish there was an accepted adapter to use a
904 behind a Big Block Mopar. There are adapters that we use in our bracket cars but not NHRA approved (I do not think any are for Mopars). Boy would that save us some money.
#10 | |
You'd have to use a flex plate spacer, along with one that would bolt up on both ends. You'll need a pilot adapter for the added length and the small to large pilot difference. Maybe there's a few guys here who could tell you how to get this one added to the seemingly nonexistent approved adapter list. ;-)
"We are lucky we don't get as much Government as we pay for." Will Rogers Last edited by Mark Yacavone; 06-30-2025 at 01:15 PM. |
