Liked 20 Times in 16 Posts
Thanks Mike,
I too have the same set up. I usually bring both phone and pager to the lanes. I should stick with just the phone.
Drew Wonderly SST 159 |
#2 | |
Liked 1,883 Times in 578 Posts
When I?m at Lebanon, we can switch some stuff around from yours to mine and see if it changes anything
Searching for Gremlins. LOL
Sure why not if we have the time. Thanks
Liked 23 Times in 15 Posts
Over the last few years I've have similar scrambled pages, or no page at all, but mostly at Nat Events. I too reached out to Altalab and was informed that someone was over-powering my little 5 watt transmitter inside my unit. They suggested that I move my antenna location to see if it would help. My antenna is permanently mounted to the top of my trailer but I had a spare antenna from an old Performaire with a 25' cable which I was able to connect and after moving it in what seemed to be 100 different locations, 6" at a time, I finally found a sweet spot and got back in business. It was easy to see when I was being "jammed" by watching the red light on the front of the Altalab base unit. When it stays on constantly you're not getting out.
Altalab said that its more prominent at Nat events. I've seen it where we run TT on Thursdays with no issues only to have NHRA.TV set up all their bs and then there goes the signal. I've thought about moving to a text system but I've seen the cell service at Nats so bad before that you can't get through at all on a phone, text or otherwise. Last edited by Dewdlebug; 06-08-2025 at 10:45 PM. Reason: Spell check |
#5 | |
Liked 225 Times in 96 Posts
That's something I have noticed.
Tony Leonard S/ST 56 S/C 53 |
Tony,
That is exactly what happens to mine. Fortunately the texting works for me so I will stick with that. Only issue I have with texting is that after I shut everything down and go home, I keep getting prediction texts for sometimes days and then it finally stops. Pretty weird.
#7 | |
I would guess the prediction texts are sent through a similar system that NHRA uses to send updates during events. Those types of messages (through the internet and not phone-to-phone) are sometimes held up by phone companies as potential spam.
#8 | |
