Old 05-01-2025, 03:04 PM   #7
Mike Pearson
Mike Pearson's Avatar
Liked 1,987 Times in 599 Posts
Default Re: Consistency
Originally Posted by Barso1514 View Post
So I run a 402 375 horse combo in a 70 chevelle weight is usually 3810 my minimum is 3635. It?s got a Tilburg motor with a Sepanek metric 200. I try to keep all my fluids everything the same temperature before the run so on and so forth that?s why I?m trying to figure out if it?s a fueling issue through the carburetor or something that I?m not looking at correctly.
Sounds like you have some good equipment there. What kind of weather station and prediction software are you using to figure your dial in? I would try to get the weight down closer to your min weight. That will help some with consistency. I use an oil pan heater to keep the oil temp consistent between rounds
Mike Pearson 2485 SS
