Old 04-27-2025, 03:54 AM   #1
Cglrcng
Cglrcng's Avatar
Liked 355 Times in 189 Posts
Default Re: And you thought air/ electrical shifters in stockers was
They were not checking underhood and the shifters for blinders. Did you actually ask what they were checking for?
Gary Lucier - 7832 STK. / 7832 E.T. EF/S Slow Sled. I am, but a simple test of your true patience. So, do all the really "Big Wheelies" you can!
Cglrcng is offline   Reply With Quote
Old 04-27-2025, 04:48 AM   #2
Cglrcng
Cglrcng's Avatar
Oh, and the most ingenious looking beam breaker I have found so far was a very well designed centered right below the bumper tow hook...Dual purpose as it could actually also be used to tow or winch the car (though the owner and driver said when questioned it's number
1 purpose was beam breaking at the top
end), we both had a laugh as he had to
re-strengthen it to use it to winch the car
with it about a year after the initial install.
Every car's front ends are different front bumper to leading edge of front tire as is tire circumference, front axle setback, etc. And the starting line beams are 3" off the ground but finish line beams are 6" off the ground. Some break the beams with the front end, some headers, some oil pan, some tires. Others front end parts (Steering gear and A-Arms)...brackets, cords or hoses hung just right also work. Not for me, but for others I have noted.
When you look for them you will find many, talk to those that have them as it is a fun topic.
Old 04-27-2025, 08:42 AM   #3
Stan Weiss
Stan Weiss's Avatar
Liked 734 Times in 385 Posts
So in effect you are running less than 1320 feet, and based on the car / model different ones will run a different length.
Stan
Old 04-27-2025, 09:03 AM   #4
Cotten
Liked 565 Times in 70 Posts
Damn, I was there for 10 days and never knew any of this was going on, including the check for blinders. I've got to start getting out of the motor home more.
Cotten is offline   Reply With Quote
Old 04-27-2025, 09:10 AM   #5
jmcarter
jmcarter's Avatar
Liked 3,193 Times in 975 Posts
After doing some of the .90 wars for a few years you learn to check the front end of cars you?re not familiar with so for me this is just part of racing. I have a much bigger issue with arbitrary rules put in place by a vocal minority from the NHRA “chosen”, such as no blinders and air shifters in Stock. Blatant favoritism is just one of my “buttons”, and it downplays the role of the SRAC.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
