Old 04-03-2025, 01:58 PM   #1
Adub464Q
Adub464Q's Avatar
Liked 478 Times in 91 Posts
Default Re: New shifter rule poll
I honestly do not care any way.
But I would truly like to see a sound argument against, other than saying it is not the way stock should be or has been over the years.
If that was the case, why were two steps allowed in the early 2000s? If you cannot footbrake your car, you should not be in stock.
The same logic from this thread could be applied to the two step argument but I do not hear anyone out hear beating the drum for disallowing two steps.
Austin Williams
3 SG
464Q STK SC
Adub464Q is offline   Reply With Quote
Old 04-03-2025, 02:57 PM   #2
Travis Buth
Liked 63 Times in 27 Posts
I would be ok with the two steps getting taken away as well, at least for the Auto cars. I am fine with stick cars having a 2 step. Have the rules similar to sportsman class in that regard.
Spts/Pro-302P
Stock-3653
Travis Buth is offline   Reply With Quote
Old 04-03-2025, 03:12 PM   #3
whompin_wedge
Liked 103 Times in 25 Posts
Agreed, take the 2 steps from autos as well!
Casey FJ
whompin_wedge is offline   Reply With Quote
Old 04-04-2025, 10:53 AM   #4
MR DERBY CITY
Liked 8,206 Times in 1,536 Posts
Disappointed with some of my fellow racers . So if YOU do not use a 2 step , then NO ONE needs to use one ?? C?mon guys, you all are better than that ….
Old 04-04-2025, 12:02 PM   #5
Adub464Q
Adub464Q's Avatar
Disappointed with some of my fellow racers . So if YOU do not use a 2 step , then NO ONE needs to use one ?? C?mon guys, you all are better than that ?.
And you just made the point I was trying to prove.
If you choose to not use an air/e-shifter, does not mean that NO ONE should be able to use one?
The new air shifter rule does not require anyone to use one.
Austin Williams
3 SG
464Q STK SC
Old 04-04-2025, 05:07 PM   #6
Bill Grubbs
Liked 564 Times in 66 Posts
There is already a lack of new blood coming into the sport. The costs will continue to rise from astronomical, to unobtainium.
Austin where does it stop? I would like fuel injection, four-link rear, CNC ported heads, air shifter, turbo's, blowers, Comp styled pistons, and any other addition that another competitor may have. I'm sure there are the stick shift guys that would like to use an air shifted clutchless transmissions (contrary to another post ProMod's are using automated air shifters, I do not know about any of the other classes).
PS, I personally know of three racers that are using an E-shift in 60's and 70's cars that had non-electronic transmissions. easy to find in a non-invasive inspection.
The secondary question will be...When stock and superstock are combined will NHRA pay out for the second car a driver who routinely enters the two classes? or...will double entrees be allowed. Then in an effort to level the playing field, will other drivers be allowed to double enter a single car, or will there be buybacks.
Once again Austin...where will this DEI program to level the playing field stop?
Bill Grubbs is offline   Reply With Quote
Old 04-04-2025, 06:39 PM   #7
Liked 5,147 Times in 1,964 Posts
Bill , If "Joe Racer" sees a perceived advantage for HIM, He'll have an automated shifter in a minute... "It's only money"
Old 04-04-2025, 07:13 PM   #8
Adub464Q
Adub464Q's Avatar
DEI?wow.
Flipping the question around you. If air shifters would result in an increase in participation, would you be in favor?
Speaking personally, I haven?t raced stock since 2021 due to racing other classes. However, there is still a stocker sitting in the shop. With an air shifter rule, I can put anyone in the stocker and have an ease of mind that they will handle the car the correct way. That?s speaking from a personal opinion.
NOTE: I am not on SRAC, or was in any way involved in the discussions with SRAC or NHRA.
Austin Williams
3 SG
464Q STK SC
Old 04-03-2025, 03:55 PM   #9
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 313 Times in 106 Posts
My logic is.... Pro Stock, Pro Mod TAD, TAFC all shift as result of driver function all performance based, non electronic classes, MY REASONING and PROPOSAL is why should Stock,Super Stock and Competition Eliminator be ANY different than the other perfomance based,non electronic classes..
.90 classes, Top Sportsman ,Top Dragster and Super Pro are electronic, bracket based classes let them use air/electric/co2 automated shifters
Old 04-03-2025, 04:01 PM   #10
JP1738
JP1738's Avatar
Liked 1,269 Times in 354 Posts
I'm with you guys on 2-steps, no idea why autos have them. I do not use one and I'm honestly not sure why I would need one.
Dawson Pauley
#2827 N/SA 1980 Malibu SW 2S 305/180
#2827 S/ST 1978 Mazda RX7 w/ 383 sbc/glide
JP1738 is offline   Reply With Quote
