Old 04-02-2025, 06:02 AM   #1
whompin_wedge
Liked 102 Times in 24 Posts
Default Re: New shifter rule poll
I am also very much against the air/electric shifter rule.
Casey FJ
3480 U/SA
whompin_wedge is offline   Reply With Quote
Old 04-02-2025, 06:09 AM   #2
GUMP
Liked 2,354 Times in 554 Posts
Put me down as AGAINST.
Daren Poole-Adams
NHRA Stock/SS 2007
GUMP is online now   Reply With Quote
Old 04-02-2025, 06:45 AM   #3
4543
Liked 643 Times in 140 Posts
Where or who did this idea come from?
4543 is offline   Reply With Quote
Old 04-10-2025, 11:30 PM   #4
DG
DG's Avatar
Liked 449 Times in 98 Posts
Do your cars have automatic 1-2 shift capability?
DG is offline   Reply With Quote
Old 04-11-2025, 07:44 AM   #5
GUMP
No. If you are driving one of my cars you are pushing a shift leaver.
I don't run a two step to stage/launch either.
Daren Poole-Adams
NHRA Stock/SS 2007
Old 04-12-2025, 04:46 PM   #6
SS3860
Liked 165 Times in 56 Posts
I probably will not put one in my car. Kinda like the ability to adjust ET a little by varying 2-3 shift.
Tom Flowers
E/SA 3860
SS3860 is offline   Reply With Quote
Old 05-14-2025, 01:04 PM   #7
ALMACK
ALMACK's Avatar
Liked 369 Times in 127 Posts
That's a big NO for me in Stock Eliminator
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 05-14-2025, 01:48 PM   #8
SDmopar
Liked 207 Times in 49 Posts
What a time we live in where how you shift your automatic transmission becomes such an emotional trigger.
Seems simple run a stick if you want to shift every gear yourself. Run automatic if you want the option to do it either way. I could care less on how my opponent does it. Blocking, shifting or stripe takers still won?t help racers who struggle. I?d prefer every one of my opponents have an air bottle. It?s one more thing that can go wrong with there run. Stripe takers will lose more runs then they will help with. Blocking is a great tool but you better be able to switch back when it gets dark. I understand the purity aspect of Stock Eliminator but her virginity was lost when we started allowing aftermarket components. I?m not the brightest bulb but I?m pretty sure edlebrock heads never came from the factory. Same could be said for Caltracs, afco shocks. Now that I pissed off everyone here let?s just realize there is nothing stock about what we do now and join together and support any group that tries to give us a place to compete. Instead of hassling and bitching about every detail.
Brian Anderson
5058 B/SA 99 Chevy Camaro SS
SDmopar is offline   Reply With Quote
Old 05-16-2025, 01:35 AM   #9
Casey Miles
Liked 502 Times in 91 Posts
So you start out with an automatic transmission, then you turn it into a manual transmission. Now you want an automatic shifter, why not just turn it back to an automatic, shifting problems are solved. You don't need to move that lever to change gears anylonger.
Casey Miles
248H E/S
