Old 03-04-2025, 08:59 PM   #1
Liked 1,836 Times in 417 Posts
Default Re: Air shifters in stock?
Originally Posted by littlemanjoe View Post
It looks like they will allow RPM shifting devices in stock for 2026.
Why do they want us to be like Super Stock?
Like Super Stock?
They were in Super (0.90) classes and bracket cars before they were in Super Stock.
I doubt Super Stock is where they're looking at taking you.....
Old 03-04-2025, 09:02 PM   #2
littlemanjoe
Liked 75 Times in 28 Posts
SECTION 11A: STOCK CARS, DRIVETRAIN: 2, TRANSMISSION, AUTOMATIC
(Page 7) (02/25/2025)
Any model transmission, same make as car, with a maximum of three forward speeds
(unless OEM equipped with more than three forward speeds). O.D. gear not required,
reverse permitted. Transmission case must be OEM or aftermarket OEM replica from a
standard, automotive application as found in the Official NHRA Stock Car Classification
Guide. Aftermarket case must meet SFI Spec. 4.1. NHRA-accepted adapter plates
permitted. Modifications to shifting patterns are permitted, provided full shift pattern is
retained. Full shift pattern must include park and reverse. Any gear change must occur
as a result of an internal function of the transmission or from direct action by the driver.
Lockup converter permitted if OEM-equipped with lockup converter and OEM
transmission is used. Otherwise, lockup converters prohibited. Electronic transmission
controls for the electric shifting of automatic transmissions to shift via internal function of
the valve body only permitted in computer-controlled vehicles only; may shift by RPM or
time only, wires for line lock, wheel speed, driveshaft speed or GPS signal prohibited.
Otherwise, any gear change must occur as a result of an internal function of the
transmission or from direct action by the driver. Pneumatic, electric, etc. controls in all
noncomputer-controlled electronic fuel-injected vehicles prohibited. The use of air
assisted or electric shifter is prohibited in all Stock applications.
Beginning January 1,
2026, RPM-activated pneumatic, electric shifters permitted. Deepened stock or
aftermarket transmission oil pans permitted. Drilling of transmission case or rear of
engine block to adapt incompatible units prohibited. Functional neutral safety switch
mandatory. Transmission brake prohibited. Tailshaft modifications for bushing
replacement, or NHRA-accepted aftermarket tailshaft, permitted. Any car running
quicker than 10.99 must be equipped with a transmission shield meeting SFI Spec 4.1
littlemanjoe is offline   Reply With Quote
Old 03-04-2025, 11:15 PM   #3
Dyno
Dyno's Avatar
Liked 685 Times in 204 Posts
I used the Turbo Action E shift in my LS1 stocker 25 years ago. Made the 1 - 2 shift perfect every time. I think NHRA did this so everyone would have the same level racing world. The pre 97 cars never had the advantage of this. Use it if you want, don't if you want. Dyno
