Old 03-04-2025, 12:27 AM   #14
SDmopar
Liked 197 Times in 47 Posts
Default Re: HP on Monday?
[QUOTE=GUMP;710140]This is a recipe for some racers to dominate for all
If you reset back to all original hp ratings the AHFS is not needed.
If people are concerned about parity then leave it alone but fix the way reductions are looked at. The current system is the best way to try to manage the parity situation. It does not adjust the combos that got excessively adjusted before the current system that?s really the only thing that requires adjustment. Somebody goes and smacks a combo there should be away to bring it back sometime.
Tear downs are probably not going to increase. Not enough $$, time, or experience.
Brian Anderson
5058 B/SA 99 Chevy Camaro SS
SDmopar is offline   Reply With Quote
