#1 | |
Liked 327 Times in 121 Posts
I have done fairly well with my Superstock Aspen
SS/LA and SS/MA. It usually runs a couple tenths or less under the index. However, it always runs at least the index. I do not remember every having a Heads Up race in eliminations the last fifteen years. They are few and far between. It was the late Larry Harroll racecar that I bought with the engine apart for $3,500.00 from his Widow after it had been sitting for decades. As long as you can run the index in bad weather or a strong head wind there is absolutely no imperative to go any faster except your personal drive. My son Jon runs SS/KA in his Duster and may get a heads up in eliminations once a year. He actually welcomes them but they are still scarce and hard to find. John Winslow for many years has run a 426 in SS/JA with good success and it is saddled with the small Carter and a bigger engine. than the 383. There are some workarounds to improve that carb but you would need to call me in private for info.
John Irving 741 Stock 741 Super Stock Last edited by GTX JOHN; 02-17-2025 at 01:55 PM. |
Liked 759 Times in 379 Posts
There you go, so in addition to the OP?s car not being legal for stock eliminator, the engine doesn’t have the best/right heads and as for super stock, nothing about his car/combo is right for building a competitive super stocker, no mind the need for “big money” to attempt to do it.
#4 | |
Liked 6 Times in 3 Posts
So the prevailing opinion here seems to be just as I felt when I looked at the outline for a ‘67 383.... carb too small to make real power. Somewhat reassuring.
What about a 71 400 combo? You get around 415 available cubes, 452 heads, and maybe most importantly, a big 850 Thermoquad. Not sure how this carburetor is viewed as a race option, but at least its big enough to not be the cork in the combo. The downside would appear to be compression; Down around 9:1. Does an engine with that little squeeze respond to modifications very well? Also, I was watching one of Bobby Fazios videos. He was talking with a guy that said he was running The Low Deck 440 combo. I went back and listened to it 3 times to make sure I heard him correctly. Anybody have any idea what he was talking about?? Last edited by LemonWedge; 02-17-2025 at 11:22 PM. |
#6 | |
I think the 383 or 440 in regular Superstock.
SS/IA or SS/JA for 440 and SS/KA or SS/LA with the 383 would be viable to run under the index even if not a world beater.
John Irving 741 Stock 741 Super Stock Last edited by GTX JOHN; 02-17-2025 at 11:22 PM. |
Liked 26 Times in 5 Posts
West Coast = Best Coast. Looking forward to a great start to the year in Phoenix this week!
The 400 isn’t terrible. The knock on some of the later engines is how far down the hole the piston is. The prevailing opinion is that might be, at minimum, difficult to overcome. I think the 71 would be the best of them, as it only got worse from there. The Thermoquad is a great carb. GTX John likely agrees with me.
Jared Jordan 9 B/SA 2024 Jeg's D7 All Star - Stock |
Liked 282 Times in 145 Posts
I believe Greg Gay runs the 400-4 barrel in his Mirada out here on the east coast. It is not a bad combo. I looked at it as an alternative to the boat anchor I am putting in my 66 Dodge. I would look at the 73 400/265. It is rated at 20 hp less than the 72 motor. NHRA rates the 72 at 330 hp and the 73 at 310. The Thermoquad is a great carb, and a lot of people forget that it was originally designed by Carter as a race carb. Not sure how heavy your car is, but the 73 motor at 3735 puts you in GT/LA. 11.05 index, and no cage needed.
Another to think about in GT is the 70 Chrysler 440/350. It is allowed the same bigger Carter as the 375 hp motor, but you must claim it as a Chrysler. The Dodge/Plymouth combo uses the baby Holley. That combo puts you in some tough classes though (GT/H-ish) at a decent weight (3500-ish?) As for the 440 low deck, it is probably a 440 combo using a 400 block with the 440 rotating assembly stuffed in it. The downside of this is you will need a short custom piston. Not sure how much money you are wanting to spend, but that option adds up fast. Most all 440 combos are going to put you in a higher GT class. GT/A-K require a cage. GT/L and down do not. Last edited by Steve Stasko; 02-18-2025 at 12:24 AM. |
