Liked 43 Times in 18 Posts
Hey all, I am purchasing a 2012 26 foot stacker with a 4k stinger lift. I have never used a stacker yet. I am looking for all tips or tricks to have trouble free towing and use of my new to me toy. The two main cars that I will towing is a 2,000 pound roadster and a 2,800 pound nova. Which car should go on top? I am assuming heavier car on the bottom? Thank you all for any input!
Grant Christianson C521 S/G,S/C, S/PRO |
Liked 443 Times in 116 Posts
Hey Grant , congratulations it's good to get some tips ..2 important things I learned make
Sure you strap the suspension down on the car on the lift and definitely strap the Lift down it will bounce on the stops ! |
Liked 1,443 Times in 302 Posts
I just went to a stacker this year and it has been great!
I asked friends that really put some serious miles on them for tips and it helped me spec out the one I have. One thing is to check the straps often to ensure they don?t get loose. Mine were pretty good and occasionally they took a click or two to snug up, but it is worth the piece of mind. Another is the dirt and gravel from some tracks can really accumulate and then fall off the car onto the bottom car so consider what is best there such as wiping the top car off from below or a cover on the lower car etc. Tire rating and pressure is super important. If you don?t have G rated tires, consider that. Also, really inspect the tongue and the hitch for potential weak points. I run a trailer toad and while it is a pain to back up in some instances, it rides like a dream going down the road! If you don?t know the loaded weight, I would suggest going over a CAT scale at a truck stop, if you download the app, it is easy and doesn?t cost much. I think it was $13.75.
James Schaechter 3163 STK |
Question: if you?re only towing one car, do you put it on the lift and leave the lift on the floor or do you put the car in and leave the lift empty over the car?
Liked 503 Times in 131 Posts
I leave the lift on the floor and park the car on it.
Eric Merryfield 1883 STK |
[QUOTE=BIGG18c;708687]Hey all, I am purchasing a 2012 26 foot stacker with a 4k stinger lift. I have never used a stacker yet. I am looking for all tips or tricks to have trouble free towing and use of my new to me toy. The two main cars that I will towing is a 2,000 pound roadster and a 2,800 pound nova. Which car should go on top? I am assuming heavier car on the bottom? Thank you all for any input![/QUOT
Have insurance on the cars.......you are a lot more likely to have a incident with a stacker with car coming free, stuff falling on car below..... I would strongly suggest also getting some fixed length straps for the top in addition to the standard 4 straps......piece of mind.....it still gets loose up there, but will not get free...strap lift down as well. Re what to put on top versus bottom, a lot of its just preference, and how well you can get it strapped, what easiest to load, etc. I have a heavier truck on the top, and a car on the bottom, major plus if you can stand on the rear bumper of the car to tighten during stops..... Truck came loose ONCE, broke mirror, got fixed straps no issues since.......tray fell on car on bottom ONCE....velcrod the living crap out of every square inch of the removable tray.....fell on the street car, just added character. Stop frequently to restrap, the top will be 80% of the loose ones.
