Old 01-17-2025, 08:04 AM   #1
JeffM
Liked 5 Times in 5 Posts
Default SBC, LS Parts New and used
Make reasonable offer for anything ? Shipping is available
2 New World Products SB Chevy Motown 2 blocks
# 084010
std. cam
842 lifter bore
3.995 cyl. bore
350 main
nodular main caps
$3300.00
TCI SBC/BBC lightweight 29.2 168T flexplate PN 399870LW, like new. Weighs 6.09lbs. Can barely see the contact patch on the starter ring. Original date was 1/19, but was only ran in the car for 2 races. Will need recertified. Excellent condition $300.00
Jesel Dogbone lifters LFD-44002 .842 Diameter set of 16 $600.00
Bryant LS Chevy crankshaft - used one season of about 50 runs - $2600
Stroke: 4.000 inch
Main size :
# 1 = 2.5587
# 2 = 2.5586
# 3 = 2.5588
# 4 = 2.5587
# 5 = 2.5587
Rod journals :
1&2 rods : 2.099
3&4 rods : 2.0889
6&6 rods : 2.099
7&8 rods : 2.099
Wet sump crank ( short snout )
58 tooth reluctor wheel
Bob Wt: 1745
3&4 rod journal ground by Shaft Tec.
Carillo rods 6.1 rods (was used with Bryant crankshaft above)
BE :2.2253
PE :0.9285
Length: 6.100
B Width : 0.938
$1000.00
Winberg SBC crank
condition: NEW
stroke: 3.496
main size: 283 chevy 2.300
rod size: 1.850
rod journal width: 1.800
bob wt.:1540
$3500
Oliver I beam 5.7 rods set of 8 - used one season of about 25 runs
BE: 2.125
PE: 928
Length: 5.7
Weight each: 575 Grams
$500.00
7" Converter - Dynamic. Powerglide input, flashed 7000 behind 327/275 hp combo. - $500.00
Jesel belt PN 31052 ? never used - in sealed package 68-Tooth, 27mm Belt Width, Fits .391 Raised Cam SBC - $100.00
Manley 221443P-16 valve springs with 23648-16 Ti - retainers, locks and 42573-16 locators (run on dyno) $150 for set.
ATI balancer pulley PN 916794 4 groove aluminum 6.430 diameter - New $40.00
ATI balancer pulley PN 916732 4 groove aluminum 6.430 diameter used $50.00
All new or excellent used condition
Comp Pushrods (ALL 5/16 ends)
7.750; 3/8; .080 wall; QTY 15; used; $20.00
CV Products pushrods (ALL 5/16 ends)
9.150; 3/8 straight; QTY4; used
9.200; 3/8; straight; .080 wall; QTY 8; used; $15.00 for all
9.250; 3/8; straight; QTY 8; used; $15.00 for all
Trend Pushrods (ALL 5/16 ends)
7.450; 3/8; straight; .135 wall; QTY 16; used; $30 for all
8.125; 3/8; straight; .135 wall; QTY 1; new; $15.00
8.600; 7/16; Double Taper; .165 wall; QTY 1; new; $15.00
9.150; 3/8; Double Taper; .135 wall; QTY 29; used but like new; $10.00 each
9.200; 3/8; Double Taper; .135 wall; QTY 13; used; 100 for all
9.300; 7/16; Double Taper; .165 wall; QTY 12; used; $100 for all
9.300; 7/16; Double Taper; .165 wall; QTY 4; new; $15.00 each
9.300; 3/8; Double Taper; .135 wall; QTY 11; new; $15.00 each
9.375; 7/16; Double Taper; .165 wall; QTY 12; used; $100.00 for all
9.375; 7/16; Double Taper; .165 wall; QTY 2; new; $15.00 each
9.400; 7/16; Double Taper; .165 wall QTY 18; new; $15.00 each
9.400; 3/8; Double Taper; .135 wall; QTY 11; new; $15.00 each
9.400; 3/8; Straight; .135 wall; QTY 8; used; $15 for all
9.450; 3/8; Straight; .135 wall; QTY 8; used; $15 for all
JRI 2010-2015 Camaro front struts $350.00 used.
Lingenfelter billet steel LS block girdle, No hardware $500
2 GM truck oil pans (1999-2006) pan only $50.00 each
superstock@live.com for any questions or pictures
shipping available for most all items. Paypal, check, or cash in person
Jeff Myers
SS3254
S1522
JeffM is offline   Reply With Quote
Search this Thread:
Advanced Search
