my origional plan was going to run a SVO motor in superstock GT, but im going to run M stock. you think i need steeper gears?
With all due respect, how much experience do you have in class racing? First, if you are talking about the Ford Racing SVO engine, it is not legal in SS/GT. The only SVO engine that was available in a production car was the 4-Cylinder Turbo engine. Yes, if you want ot be competitive, you need steeper gears from 4.88 to 5.14, and if you have an automatic, you will also need a low gear set in your transmission.
not much experiance. The SVO engine is the 4 cyl motor that i was talking about. ill use the 5.3x gears that i have then.
#4 | |
SS/GT is a V-8 engine class. |
hmmmm. cause when i called cali, they said it would be SS/GT for the 4 cyl. I work at a race shop in omaha, ne and have been talking to some local racers in div. 5, just this is a new idea.
#6 | |
Liked 275 Times in 76 Posts
The SVO was only available as a manual trans. No auto
