Old 12-24-2024, 05:43 PM   #1
Woodfin
Liked 288 Times in 109 Posts
Default Re: Square 10
Frank, Thank you. It is a simple, basic, bracket toy for local tracks. It will run about a 6.30 ET with a 383 SBC.
Old 01-12-2025, 07:42 PM   #2
Woodfin
Switching over to engine assembly and related components. the firewall forward to mostly ready for paint.
ID:	71894   Click image for larger version
Old 01-13-2025, 08:01 PM   #3
Woodfin
Around twenty years ago, I considered replacing my old sealed power manual ring grinder with an electric model. Each time I would consider doing so, I would convince myself I would only do a few more engines, so I would get by with what I have. Well, now I am age 77, and it is a slow, tedious, time-consuming task with the old manual tool. But I will only be doing a few more engines. Old fellows, old tools, old ways that define me. I average about 45 minutes per cylinder to gap rings, assemble the rod to the piston, work with the pin clips, and install the piston and torque rod. Then, a break to look things over, ponder, daydream, and perform other necessary duties. So, it is really an hour per cylinder. And this is with everything already clean, already checked, and everything laid out.
Also note my 50 year old ring squaring tool.
Larry Woodfin
ID:	71896   Click image for larger version
Old 01-17-2025, 08:01 PM   #4
Woodfin
I have been known to say I do my best thinking, err, hallucinating when mowing or driving. Since it is the off-season for mowing, my thinking is confined to driving.
The following photos show my revolutionary design to replace valve springs. The idea came in a dream, spawned by the toughness of cable ties. The tails are located outside the valve covers to allow tension adjustments.
ID:	71906   Click image for larger version
ID:	71907   Click image for larger version
Old 01-22-2025, 08:08 PM   #5
Woodfin
progress
ID:	71947   Click image for larger version
ID:	71948   Click image for larger version
ID:	71950   Click image for larger version
Old 01-23-2025, 11:29 AM   #6
Greg West
Liked 52 Times in 22 Posts
Just curious, is that a oil temperature gage line in the oil pan or is it a line for a oil heater? Thanks
Greg West is offline   Reply With Quote
Old 01-23-2025, 08:18 PM   #7
Woodfin
Greg, it is the power cord for the oil heater. It's a Steff's item. This is my first experiment with such an apparatus.
Old 02-02-2025, 03:27 AM   #8
doglover44
doglover44's Avatar
Liked 493 Times in 231 Posts
What class is this going to run ?
Jake Biermann
doglover44 is online now   Reply With Quote
Old 02-02-2025, 05:03 PM   #9
Woodfin
Jake, local, top bulb brackets.
Old 02-03-2025, 06:12 PM   #10
Woodfin
A fine Monday afternoon to all. Be sure to notice the 5 - 7 crossfire enhancement.
ID:	72006   Click image for larger version
ID:	72002   Click image for larger version
ID:	72004   Click image for larger version
ID:	72005   Click image for larger version
