Liked 212 Times in 92 Posts
I don't have stainless headers but I saw Jon Kasse on YT I think saying that he has seen rust particles on top of the throttle blades! His assumption is that there is enough pulsation to move a rust particle from the header to the carb. I could see a backfire doing it. Here in the rust belt every first start of the season leaves lots of rust on the floor. He actually suggests a starting sequence where you get to 3000-4000 rpm as fast as you can after the engine lights. In my mind this adds an important reason to go stainless. I just curious are they building with 300 series stainless or 400? Ray
Ray Bassett I/SA 1687, SS/DA 1687 "SuperPro is both", unknown |
#2 | |
Liked 759 Times in 379 Posts
The only reason to go with stainless is weight savings but don?t expect the weight savings of stainless headers over mild steel to show anything on the time slip.
Liked 71 Times in 38 Posts
There is not. Stainless also looks like shyt when it heat cycles and is prone to cracking.
Liked 535 Times in 110 Posts
Gee, I've had the same set for the past 15 yrs. and they haven't cracked. It's also really nice to crawl under the car and not worry about getting rust in my eyes from mild steel headers. Easy to take apart as well as the collectors don't get rusted on. Once you go stainless...you won't go back.
Jim Kaekel 3836 STK |
I’ve never had any any of your issues with mild steel, ceramic coated headers and mine still look as the day I installed them. Yours look like shyt!
FYI, the original set on my Firebird were 18 years old before I replaced them. Last edited by 1320racer; 12-03-2024 at 09:54 AM. |
Billy I never thought of that. Does the plating flake or discolor? I would think this would be a method to brand new headers and not used headers?
Merry Christmas, Ray
The people who I deal with will only do new headers. I don't know about other outfits. It doesn't flake but it does discolor just like a stainless header. IMHO, much better than any ceramic coatings that I've dealt with. Not saying that all ceramic coatings are bad.
The best at applying ceramic coating to headers is Central Connecticut Coatings. Gene has been coating my headers going back 30 years. His coating has never failed in any way. He also does powder coating from full chassis to the parts.
