Old 11-15-2024, 08:36 AM   #1
Mike Pearson
Mike Pearson's Avatar
Liked 1,977 Times in 597 Posts
Default Re: Bring back MINESHAFT RULE
Originally Posted by Paul Wong View Post
That cant work because it wont take into account any fast altitude track.
The mineshaft rule was a good thing that should be put back in place.
They could have an adjustment factor the Same as they use for the index at altitude corrected tracks. Or just get rid of the altitude correction all together. Then the fast guys could run all out at the higher altitude tracks. I race in the SE so we don?t have any high altitude tracks here. I do agree to bring back the mineshaft rule. Here in Fl we can see DA in the minus readings and baro above 30.30 in the late winter AMS early spring at Orlando and Gainesville. It?s rare though. Typically that type air is 2-3 tenths faster than usual air.
Mike Pearson 2485 SS
Old 11-15-2024, 10:35 AM   #2
James Perrone
Liked 1,863 Times in 435 Posts
Mike, let?s put mineshaft where it once was when more than half the field Is 80 under whatever it was that?s telling you the weather is good for everybody
When the weather is killer, that?s when you need mine
Let?s go back to what we had
It only comes in effect when the weather is killer
james perrone 1290 STK
Old 11-17-2024, 01:24 PM   #3
Mike Pearson
I can agree with going back to what it was originally.
Old 11-15-2024, 10:53 AM   #4
west coast
Liked 230 Times in 75 Posts
Here is why the AHFS doesn't work. No body wants to get HP I get it but when NHRA and the manufacturer give bogus ratings on cars and NHRA swipe of a pen or a drunken night on the keyboard and makes the 302 🚀 rockets ships. It needs to be evened out. Not putting runs in the ahfs is not a solution. The mineshaft and Indy not being in the ahfs also the whole Dutch classic this year you cant fix what everybody is complaining about that the ahfs wont work. Let's go back to yesteryear and let officials come up to you at a race and give you hp, because the way it's going nothing will be solved. I don't believe blanket index change will solve anything. The J K L indexs need to be fixed if there are others like this they would also need to be fixed. We need a couple get out of ahfs jail free cards for races on the west coast.
James Boyce 6052 K/SA Stock
National record holder 2015,2018,2 times in 2022,2023
west coast is offline   Reply With Quote
Old 11-15-2024, 11:04 AM   #5
Yeah, no. Having an individual, basically accountable to no one, have the power to arbitrarily just hand out HP, is absolutely absurd.
A properly formulated system, published openly, is the only way to do it fairly. If people work within the system, well, that's called playing within the rules.
If you're looking for a level playing field, where everyone is always equal, you ain't gonna find it.
Old 11-15-2024, 11:19 AM   #6
JP1738
JP1738's Avatar
Liked 1,315 Times in 359 Posts
We do have Bristol tbf, air blows there, especially in June when they host the national.
Dawson Pauley
#2827 N/SA 1980 Malibu SW 2S 305/180
#2827 S/ST 1978 Mazda RX7 w/ 383 sbc/glide
JP1738 is offline   Reply With Quote
Old 11-15-2024, 11:55 AM   #7
James Perrone
Let the qualifying sheet tell you it?s mineshaft
Not the weatherman
Weatherman like politician can?t trust them
Also 120 under get an instant hit
Make class racing great again
Old 11-15-2024, 12:13 PM   #8
west coast
I got in to this class because it a performance based class. Need more heads up racing, less classes combine auto and sticks. Enforce the rule book, more teardowns. Possibly 1lb weight break between the classes
Old 11-15-2024, 12:25 PM   #9
Not the weatherman
I don't trust weathermen any more than I trust politicians.
However, an actual formula taking into account barometric pressure, relative humidity, and grains of water in the air is purely scientific.It tells you the true effect weather has on performance potential. Just like the SAE correction factors for an engine dyno. They're not perfect, but they're based on reality and scientific fact.
The qualifying sheet tells you how hard a percentage of people are pushing their combination, with weather as a contributing factor.
Old 11-15-2024, 01:22 PM   #10
442OLDS
442OLDS's Avatar
Liked 282 Times in 103 Posts
Let's say I'm at a race like St Louis where it is pretty fast.I get a heads up run and all I can go is about 8 tenths under.I'm going to get beat badly by my opponent since he probably can go 1.30 under.He gets a really bad light,tightens the stripe,and still runs 1.05 under.
With the mineshaft rule in effect where half the field was at least .85 under,he will not trigger? But if the mineshaft rule is not in use,he will trigger at one second under?
Is that how the mineshaft rule works?
