Old 11-06-2024, 10:25 PM   #1
Adger Smith
Liked 880 Times in 311 Posts
Default Re: Cylinder leakage test
Dan,
The Grump could have fit right into the aircraft industry.
He would have been spot on how it is done.
Leakage for aircraft is low % per cylinder and close on the variation cylinder to cylinder
Adger Smith (Former SS)
Old 11-08-2024, 09:48 AM   #2
rebelrouser
Liked 8 Times in 3 Posts
Yes, a NA engine with tight end gaps should test better than 10% on a warm engine a cold engine will read slightly more leak down. A large gap nitrous or blower engine will leak more cold. What I do is leak my engines on the stand when fresh right after taking them off the dyno cold, save those numbers. Then you have a baseline, when leakage starts to increase, I know it is time to save my pennies for a rebuild. I don't race class just bracket and index, but I see very little loss in ET until leakage gets about 30%
rebelrouser is offline   Reply With Quote
