Old 11-01-2024, 10:32 AM   #1
Mike Pearson
Mike Pearson's Avatar
Liked 1,939 Times in 583 Posts
Default Re: Cylinder leakage test
A leak down checker is just a tool. It is mostly used to diagnose an issue in the cylinders of the engine. its a comparison tool. If you have a baseline for the engine when it is performing properly then you have something to compare it to down the road if you are having issues with performance. Typically anything better than 10 percent is considered good. Leakage by the intake valve is the worst and even a small leakage past the intake valve will effect the performance of the engine. The exhaust is typically not as sensitive.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
