Liked 226 Times in 115 Posts
Finally found a product bulletin on this tire. I still only have 9 passes on these tires. I'm pretty sure I can win on them.
I hope to get more testing/racing on them this fall. https://www.hoosiertire.com/images/c...30%20(002).pdf |
Liked 226 Times in 76 Posts
Anyone noticed a difference in radial vs bias ply for et predictions? Just wondering out loud if the softer sidewalls could introduce more variability. Probably overthinking, but not afraid to ask the 'dumb' questions either.
Andy Friar |
#3 | |
Liked 225 Times in 96 Posts
Now, I've never seen a car that just couldn't handle radials either, but I've had to work on my own car a couple times after making a somewhat significant power increase.
Tony Leonard S/ST 56 S/C 53 |
#4 | |
I weighed the tire & rim configuration between my M/T PBRs/double bead lock rims to the FSS tires/Weld no beadlock rims. There's a total difference of 24 lbs. weight savings. Hopefully they work good enough to use for the Spring Fling Million in Apr. if I decide to enter. 1700/STY/781L ![]()
You earned/deserve the vast majority of unfriendly & different names earned by you due to your BS. Embrace them names, they're the Real Truth. ![]() |
Liked 95 Times in 24 Posts
If the Hoosier 18213 is 94" circ. and this tire is for factory stock, what rear gear do they run and how much horsepower are those cars
#6 | ||
Below is/was my gearing. I have no idea on the HP, it hasn't been on the dyno. 1700/STY/781L ![]() Quote:
#7 | |
Liked 1,436 Times in 299 Posts
The only 9 inch PBR I have seen is only 28? tall and 88 rollout. What size were your PBR?s?
I ran some 13.5 x 31 PBRs for years for an everyday slick on my Cavalier LT1 stick car. When I took them off last fall at Vegas, they had 193 runs on them and looked great! The date code was from 2017 and I bought them in 2018. I gave them to a local bracket guy? They were 9 lbs each heavier than a standard radial but you cannot wear them out! Quote:
James Schaechter 3163 STK |
#8 | |
When I first started running radials many...many moons ago. I started with a Hoosier 30 x 9 C06 lightweight & got an easy 150 runs out of them. I've ran all the different model 9" Hoosiers. They're great tires, but the PBRs edge them out slightly for bracket racing. 1700/STY/781L ![]()
#9 | |
Performance wise, the total rotation weight savings made little to no difference in ET & I wasn't looking for one. I decided to enter the Spring Fling Million & parking is one week from today. I'm going to double enter in Pro & Super Pro for the (3) 30K races & single enter in the Wanna-Be Million. 1700/STY/781L ![]()
You earned/deserve the vast majority of unfriendly & different names earned by you due to your BS. Embrace them names, they're the Real Truth. ![]() Last edited by 1700camaro; 03-24-2025 at 11:54 PM. Reason: Because I Can |
#10 | |
