Old 08-16-2024, 10:01 PM   #1
Gmirza
Liked 253 Times in 95 Posts
Default Re: Keizer Wheels
I just receive a pair of Verbrands. 15x9, very nice looking wheels. I had Roy (D1 Hoosier guy) mount and balance a pair of 30x9 radials on them. No problem and they balanced up good. Ill see how they work when I put them on. American made, good quality and reasonably priced. How can you beat that.
George Mirza
D/SA 1236
‘71 Duster 340
Gmirza is offline   Reply With Quote
Old 08-19-2024, 02:14 PM   #2
cad
cad's Avatar
Liked 91 Times in 51 Posts
A very good friend has had 15x14 SBL rears and skinnies on his 2015 tube chassis Camaro, BBC, 5.40 bracket car, and has had ZERO issues.
And, they look great.... mfr in Alton, Iowa.
Clark
Old 09-17-2024, 06:29 PM   #3
1700camaro
Liked 226 Times in 115 Posts
Update to our Keizer wheels:
While we haven't hit the track with them yet, but hopefully at the end of this month. The wheels/tires are mounted & installed on the car.
We have one rear wheel or tire that's leaking air about 9 lbs. over 2 weeks. I'm assuming it's from the beadlocks, but have to check them. The tires were previously mounted on Weld Racing non-beadlock wheels with no leakage.
The front wheels are good, but I had to replace a new front tire that had a small bulge in the sidewall. No issue with the replacement tire.
1700camaro is offline   Reply With Quote
Old 09-30-2024, 06:26 PM   #4
1700camaro
We raced the new wheels this past weekend & the new radial front runners,
no issues. Plenty of compliments on their looks & not being the mainstream wheels that most are using.
Old 09-30-2024, 09:16 PM   #5
Gmirza
Nice! I put mine on a few weeks ago. Fit perfectly, hold air well, run nice and true. Look pretty good also. A good quality, reasonably priced American made product. How can you beat that!
George Mirza
D/SA 1236
‘71 Duster 340
Old 10-25-2024, 06:39 PM   #6
1700camaro
I thought I had mentioned that Keizer or Moser stated when I bought my double beadlocks. That I might have to go to smaller diameter rotor with matching caliper bracket to clear the caliper when using double beadlocks with 15" rims.
Just for information, I had no issues with the Moser calipers clearing the rim & have plenty of room. I did buy the smaller diameter kit but like stated it wasn't required for our set-up.
