Old 08-08-2024, 11:18 PM   #1
Rory McNeil
Default Re: Help with a Ford Maverick
Mavericks with either the 250 cube 6 cylinder, and the 302 V8s had 5 lug wheels, the smaller (170 and 200 cube) 6s were 4 lug. Are you trying to replace just the outer drum, and reuse the old hubs? If so, I have never seen a factory Ford front brake drum that had a seperate drum and hub, unlike older drum brake GMs, on the Fords, the drum and hub are 1 piece, the hub is not meant to be removed from the drum.
NHRA 6390 STK
M/S 85 Mustang
