Old 08-07-2024, 05:37 AM   #1
JeffM
Liked 5 Times in 5 Posts
Default LS/SBC parts - Wheels, Converters, misc
Weld Alumastar 15 x 12 rear wheels with 4.75 pattern and 3 BS. $800.00. Very good condition, no screw holes
TCI SBC/BBC lightweight 29.2 168T flexplate PN 399870LW, like new. Weighs 6.09lbs. Can barely see the contact patch on the starter ring. Original date was 1/19, but was only ran in the car for 2 races. Will need recertified. Excellent condition $300.00
Jesel Dogbone lifters LFD-44002 .842 Diameter set of 16 $800.00
LS Bryant crankshaft 4" stroke 58x - $2800
Carillo rods 6.1 rods (was used with Bryant crankshaft above)
BE :2.2253
PE :0.9285
Length: 6.100
B Width : 0.938
$1200.00
Forged small journal 327 GM crankshaft. Offset ground (.020 under) by Shaftech. 1.979 rods, 2.300 mains 3.263 stroke $650.00
Oliver I beam 5.7 rods set of 8 (was used with Shaftech crank above)
BE: 2.125
PE: 928
Length: 5.7
Weight each: 575 Grams
$700.00
8 ATI converter - Flashed 6500 behind 427/430 LS Combo Powerglide spline - $500
7" Converter - Dynamic. Powerglide input, flashed 7000 behind 327/275 hp combo. - $500.00
Wilson 4 hole aluminum tapered spacer. Dominator flange PN 024110 - $150 used for test only
Manley 221443P-16 valve springs with 23648-16 Ti - retainers, locks and 42573-16 locators (run on dyno) $200 for set.
ATI balancer pulley PN 916794 4 groove aluminum 6.430 diameter - New $40.00
ATI balancer pulley PN 916732 4 groove aluminum 6.430 diameter used $50.00
CV products 3/8 pushrods (qty 18) 9.200 x .080 x 5/16 ends used but good condition $30.00
Trend 3/8 pushrods (qty 16) 7.450 x .135 x 5/16 ends used but good condition) $50
Trend 7/16 tapered pushrods (qty 16) 9.400 x .165 x 5/16 ends new - $150
Trend 3/8 pushrods (qty 8) 9.400 x .135 x 5/16 ends used - $25
Trend 3/8 pushrods (qty 8) 9.450 x .135 x 5/16 ends used - $25
Trend (qty 17) 9.150 DBL taper .135 wall pushrods 5/16 ends (used good) $35
Trend 9.400 DBL taper .135 wall pushrods 5/16 ends (11) new $150
Trend 9.300 DBL taper .135 wall pushrods 5/16 ends (11) new $150
JRI 2010-2015 Camaro front struts $500.00 used.
Lingenfelter billet steel LS block girdle, No hardware $500
2 GM truck oil pans (1999-2006) pan only $50.00 each
superstock@live.com for any questions or pictures
shipping available for most all items. Paypal, check, or cash in person
Jeff Myers
SS3254
S1522
JeffM is offline   Reply With Quote
Search this Thread:
Advanced Search
