Old 05-31-2024, 11:27 AM   #11
B/S 428
Liked 154 Times in 34 Posts
Default Re: U/SA 302 ffffford build
Glenn, I'm thinking the same way that you are (I guess that I can throw away a set of Aardvark heads). The online rules specifically says "VALVES must retain original valve angle +/- 1*. It does however say ANY valve job is legal which I will Assume (NHRA likes to keep us Assuming) goes to seat angles.
I think that I'll start a thread in the tech section. This needs to be discussed.
JMO the valve angle +or- they're talking about is the angle of the valve guide and any valve job means any valve job. Brian Seaberg 627
B/S 428 is offline   Reply With Quote
