Old 05-30-2024, 12:18 PM   #1
Billy Nees
Liked 7,745 Times in 1,740 Posts
Default Re: U/SA 302 ffffford build
If I might interject here, for those doing their own valve jobs..Stock valve angle is required in Stock , + or - ! degree.
Yeah Mark, it ain't that way anymore. Any valve angle, any number of angles but no further down than the valve pocket and must hold NHRA's runner volumes.
OH YEAH, it has to LOOK "Stock". ;-)
Well ya know? I just re-read the rule book any YOU are correct!
You are however allowed to CNC port the intake/exhaust runners and the combustion chambers! If you're running a FS car. Now that hardly seems "fair"!
Billy Nees 1188 STK, SS
Old 05-30-2024, 05:07 PM   #2
goinbroke2
Liked 393 Times in 153 Posts
4th sentence says “must retain stock diameter and angle + - 1*”. But the 4th sentence from the bottom says “any valve job accepted”?
Well i did 4 angles (cant find my 75* ) 15 in the chamber, 30 below that, 45 seat and 60* in the throat. Im pulling my hair out because the flash and casting crap as well as the lip left from the 15 cut is killing flow but i cant legally remove it. Stock casting SUCK!! Lol!
So much easier to make power when you blend, lol.
Jim Miller
103 U/SA
Old 05-30-2024, 05:59 PM   #3
Billy Nees
You can use a radiused cutter. That's not illegal.
Old 05-30-2024, 10:29 PM   #4
Liked 5,124 Times in 1,953 Posts
My Citation HO 2.8 came stock with 5 angles..That made tech nuts, for sure, at that time
Old 05-31-2024, 01:19 PM   #5
pmrphil
Liked 348 Times in 152 Posts
Stock valve angle in a small block Ford is 20 degree VALVE angle - relative to the deck/cylinder head surface. ANY valve and seat angle(s) for a valve job are permitted.
Phil Molski
PMR Performance
S/C 1623
Old 05-31-2024, 01:52 PM   #6
I'll reply in Billy's tech thread.
Old 05-31-2024, 07:30 PM   #7
goinbroke2
Just got in from the garage and wow, I kicked over a hornets nest! All good though, it'll be clarity for the next guy with a seat cutter and rules comprehension phobia!
gotta go, but today I finished the heads, put light springs on for break in and no valve seals. When it's broke in and I'm putting the big springs in, I'll put some seals on the intakes as well.
Jim Miller
103 U/SA
Old 06-01-2024, 07:28 AM   #8
Billy Nees
Don't get carried away with your valve spring pressures!
Old 06-01-2024, 08:35 AM   #9
goinbroke2
But Billy, im going to scream this to 5000, i need big pressure! 😂😂
I was already told im way too high, ill adjust to what was recommended.
Jim Miller
103 U/SA
