05-22-2024, 05:27 PM | #1 |
Liked 167 Times in 77 Posts
one or two batteries?
SS/GT cavalier...not sure which way to go. any advice please...i plan to run an alternator.
05-22-2024, 07:02 PM | #2 |
Liked 2,118 Times in 608 Posts
Re: one or two batteries?
I you need the weight anyway = Why not run a
second battery. We do in our cars.
05-24-2024, 05:58 AM | #3 |
Liked 2,932 Times in 901 Posts
What’s nice about GT is class flexibility, if you need the weight then what John said. If you’re looking to be able to move up in classes occasionally then it’s a lot easier (and cleaner) to just remove weight bars.
05-24-2024, 06:11 AM | #4 |
would any ony have a battery cable diagram to hook up two batteries using charging lugs and required kill switch in the system...tks !
05-24-2024, 10:12 AM | #5 |
Liked 709 Times in 213 Posts
I totally agree that if you need weight, might as well be a second battery. One piece of advice that I learned the hard way, between races, separate and load test the batteries individually. If one of the batteries goes bad, it will take the other one down with it.
05-24-2024, 01:15 PM | #6 | |
Liked 1,740 Times in 551 Posts
if you must run two batteries consider running an isolator you could even put a switch inside the car in case one battery goes dead. Hit the switch and you’re up and running.
KEITH MAYERS 2 X somebody many X nobody |
05-25-2024, 08:22 AM | #7 |
Liked 10,057 Times in 2,087 Posts
We run two batteries in the Cuda each weighing 11.5 lbs one in stock location one in the trunk. We lost a little weight off of the front. Dumbo only has one in stock location.
05-26-2024, 11:01 AM | #8 |
looking for wiring diagram for this application if anyone has one please
