Liked 372 Times in 129 Posts
In the picture its hard to see but both the intake and exhaust valves are sunk quite a bit, probably to get CCs and piston to valve clearance, which I will check so I can get my heights setup before any work is done. Flow testing was done @ 28 inches, 4.350 bore, SF 600.
Short port: .100 73 .200 131 .250 154 .300 181 .350 208 .400 232 .460 243 Long port: .100 73 .200 132 .250 161 .300 185 .350 210 .400 235 .460 257 Exhaust: No pipe .200 107 .300 131 .400 152 .480 165 One thing to note, when a BBC head is flat milled to the extent this head is, flow is lost, although I understand CCs have to be met some way, it's definitely a juggling act. At this point I will clean the head, then locate the highest (closes to the piston) intake and exhaust valve and check piston to valve clearance then CC the chambers, after this the cylinder head restoration will start with pictures. If anyone has flow data for this type of casting in Stock Eliminator trim casting numbers, please feel free to post along with opinions. 063 215 290 Last edited by HP HUNTER; 05-19-2024 at 08:40 AM. |
Liked 482 Times in 159 Posts
Chev V8 Big Block Cylnder Head 3964290 Small plug Flow Data - unported
Data Source Int/Ex Valve .100 .200 .300 .400 .500 .600 Chevy 290 Oval Port Iron CHP 01 253.0 / 112.0 cc's, Exhaust = No Pipe 2.065"/1.725" 60/47 122/88 172/113 214/133 244/152 256/161 Chevy 290 Oval Port Iron CHP 02 253.0 / 112.0 cc's, Exhaust = Pipe 2.065"/1.725" 60/47 122/90 172/118 214/138 244/160 256/174 Special thanks to Stan Weiss for supplying data. This is only a small detail of information available on his website. It is worth the time to dig into his stuff at |
Liked 973 Times in 310 Posts
Flow test should be done with correct bore size or you could be getting incorrect data.
I will agree, but I'm just looking to see the gain, I will not buy a bore sleeve and top plate for this small bore project. I've been very impressed with your qualifying, great work!
Liked 780 Times in 194 Posts
Did you pour the intake and exhaust ports for volume?
Liked 880 Times in 311 Posts
Mark,
since I'm not well informed about the stocker combinatons... What year and body does the 335 HP 396 fit? I found the small cam 1969 335 HP 427 in Dwights class tool section
Adger Smith (Former SS) Last edited by Adger Smith; 05-20-2024 at 12:35 PM. Reason: add |
