Liked 408 Times in 209 Posts
Gary Lucier - 7832 STK. / 7832 E.T. EF/S Slow Sled. I am, but a simple test of your true patience. So, do all the really "Big Wheelies" you can! |
![]() I missed the first 2 Div. races of the season along w/ the testing at Las Vegas through the Bracket races I had also planned to test the DF/S weight, also missed Crewing for Scott McClay at same events at Phoenix, but lived through the illness to race again. Next up a S/SS Combo race and some good test dates earlier in March to ready for it once healthy again, We secured the Storage in Las Vegas at the end of January, and moved the car to Las Vegas early March, right after I recovered. Better a late start to the season than a never start! Las Vegas, Summit Bracket race #6 Mar. 9,2024 was the first chance I had in 2024 to test the car in DF/S trim. And did something really stupid with the slicks (live and learn, even late in life), because I was tired of them leaking down slightly at night. It involved Slime, and that just unbalanced the tires and rims so bad I removed them immediately after 1 single pass, had my wife take them to a tire shop and they would not touch them, ended up taking them home, asking Big O Tire on Monday to break the beads for me, took them home and flushed them both out with water till clear, took them back to Big O Tire (Thanks guys!), I then had them fully dismounted, Dried off inside, coated w/ dawn dish detergent air dried, had the beads of the rims cleaned well, and remounted and balanced perfectly fixing the issue properly. In the meantime I made passes on the Street tires on that Saturday, and a test day on Sunday at Las Vegas for an import race (I was able to get a dozen hot lap test passes), in on Sunday (making small minute changes, to ignition timing (among other things, fan on/ fan off, just a bunch of do these things make it faster changes...nope on all but 1 of them), both up and down, etc. and it allowed me to test a few theories, most of which were immediately reversed, since none were for the better (the car is pretty solid as is, but I noticed it had developed a minor rear cam seal leak after the first 6 hot lapped passes, just a tiny leak, and only when seriously hot lapped, but a leak all the same. I cleaned it between passes and made sure I replaced that seal before the combo race in a week. Though track prep was good for the first 2 passes Sunday morning, there were a crapload of very fast FWD Turbo or otherwise boosted nitrous FWD cars that instantly wore all of the rubber and glue off the track in both lanes in only the FWD tire stage areas, and there just were not a lot of Rear wheel drive cars running at that Import Event to lay down rubber on the bare patches, so for the first time in forever it was hit and miss on spinning on my street tires, hook 1 time, spin the next...But, I cannot complain, I only paid 35 bucks for an all day test session! (Scales were of course not open, and will not be until the 4 Wides Nat. and the LODRS Double at Vegas).
Next race date up was at Las Vegas, the MATSLV S/SS Combo (Put on by Phil Mandella), Fri. Sat, Sun. Mar 14-17, 2024 and I entered, it rained a lot, we had wind, usual Spring weather, but a lot wetter than normal, and finally got Qualifying and the race in after a lot of track drying and on track incidents, wrecks, popped chutes behind the starting line, etc (not those competing in the combo), but all the other classes they were running. It was a fantastic time, fun in all respects, I will return to it again next March, I just was flat worn out by the time we finally got to stage up for first round Saturday evening after an extra hour and a half due to a big wreck cleanup, and a huge temp drop outside, and I was aced out at the tree By a Kennedy Brother in a very fast hard charging Bright Yellow Mustang Fastback. And there was still time to call for my ride to storage, get the car put back in towing trim, loaded up, move it across to the spectator parking area, get a lift, get the car safely tucked into storage, as my wife was already on the way, and grab a good meal before she arrived, get home late Saturday night and sleep in my own bed. Sadly I missed the rest of the rounds. I did read about them though, Thanks to all I had fun, but...
Through all the changes to get that car down close to DF/S weight, it just is not ready to go that direction (yet), as I could not even get it to run in the high 16's in the Altitude of Las Vegas reliably. And it needs to reliably run at least a 16.85 Corrected Index. I did in testing hit close to it twice (both high 16's), but not that weekend, I was more like 17.09-17.11 (in Drive), reliably where I short shift at 5,200-6,200, or 5,400 -6,400....Future changes will allow me to go there (Converter loosened, higher stalling leave, Manual brake conversion, back to the higher lift cam, and The planned tap/tap/laptop tuning of an aftermarket EFI ECU system upgrade that I can actual lean out finally in the rotten Las Vegas Air conditions. All those are still planned changes (some sooner than others), but, I put it immediately back into EF/S weight Trim before the April 4 Wides, and the LODRS Double (plus 2024 Div. 7 Class Racing), that I registered for (also was set to crew at all 3 of those races for Scott McClay in his Comp Elim. Entry)....More on that in the next hr. or so!
Back to that month of December 2023, I wasn't just staring at the car, I was doing a deep dive into all the available data from the very first trip to a drag strip with the car, all the trials and tribulations of attempting to turn the slowest budget class car in the world when it fit in FF/SA, but I ran it in GF/SA, into at least a great consistent slow bracket car (all the troubles it started having after my first half dozen wins in the Street Bracket, and those issues just about started when I started messing with the car to make it faster to start competitive Stock Eliminator racing it in early 1994, then things progressively just got worse and worse in 1995, 96, and 97. Leading me to park the car until I could get a real hold of and resolve the issues.
That part has been resolved. Since I started bracket racing in 1975, I drove a lot of slower cars, street was the starting point, driven some that were very consistent though slow, and some that were not. Some were easy to win with, and some never garnered a win no matter how hard I tried...like my very first 4 speed race car. That was a long 8 month drought, I could not sell that 62 Dart fast enough. Then, I purchased a 63 Polara, because a friend needed cash, and lucked out into the best (wininningest), race car I ever owned, it was built or prepped by Peter Berkuta (sold it to Richard Gabaldon, the first time Pete drove it to tempt Richard into buying it, Pete won with the car that night Heavy Bracket 3, a week later Richard won the same with it first time he raced it, and a few months later (I had expressed an interest in buying it), he called, asked if I had 3 grand cash, I did, went to the bank on the way to Terminal Island - Big Willy's LA Harbor outlaw track, met me there, and sold me the car, and in a couple of hrs. I won with the car, then a week later after a 3 hr. track rental at O.C.I.R in Irvine, CA I won a big Popular Hotrodding Magazine race with that car, and a lot of wins followed that 1, more than any racer deserved, as it was one of those fill drive it to the track, fill it up, runi it, dial down a hun and run dead on w/ a zero kind of Bracket cars. Just drive it the same, and it was a winner, but it was an 11 flat Mopar, running 12 flat, as it hade no rollbar or cage, and I loved the 5 amber 5/10ths tree w/ flood lights. It was just a magic Bracket car, a more than a few called me Lucky! Socal racing in those days, either driving it to/from the track, or trailering it, there were so many tracks from Carlsbad, to insland empire Riverside, Irwindale, O.C.I.R., T.I., LA County Raceway, Bakersfield, it was the heyday of Southland tracks for any NHRA Bracket racer, each track was open at least 2 days a week, and we could race somewhere, everywhere 5 to 7 days a week, and you could catch a race on the way back from wherever you raced last night, catch a few zzzzz's in the car upon arrival, and race again tomorrow. So, looking at all the data, from 1993 forward on this slow budget Stocker, it is currently a very consistent slow Bracket car. One of the most I have ever driven of you look at it from a driver perspective (it has had a few little new build bugs since I first ran it on a quarter mile strip again last September) , but those were to be expected to pop up. Fixed em moved on. The car is sound, the car at elevation is slow, but that trip to Pomona shocked me (- .126 under at Vegas, nearly 8/10ths under at Pomona in 3 passes -.797 under). My deep dive said I saw those numbers before at Pomona in Feb 1995 log book showed 3 passes -.701, -.703, and -.721, then I broke a timing belt mins from E1 Sunday. Now, the driver, I sat out of the sport completely for 26 yrs., I knew it would be a tough return at 66, no longer a kid, no longer even middle aged, and the biggest 3 challenges were, the LED Tree, no longer 11-12 spots on an incandescent bulb to choose from for a spot to leave on (crap, in my heyday of decades long gone by...mainly the 1984 season, I foot braked, and counted down on a 5 amber tree from the top bulb down, nodding my head at the center of every bulb), try that on an LED tree.
Gary Lucier - 7832 STK. / 7832 E.T. EF/S Slow Sled. I am, but a simple test of your true patience. So, do all the really "Big Wheelies" you can! Last edited by Cglrcng; 05-02-2024 at 06:38 AM. Reason: Spelling, etc. |
I had red light itis the entire 4 races plus I ran from September forward to the end of the year in E1 except adjusting to a single day of .030, .031, and .033 lights at Bakersfield Q1, C1, and E1, then next day went red again in E2. Pomona was off the trailer .020 Q1, .010 Q2, and -.008 again red E1 (though - .666 to -.797 under index in lower elevation and good air). (The absolute bane of a locked stock ECM/PM with virtually zero tuning capabilities...So far).
But, I long ago grew up racing at my night owl time of day, not many early morning races. It was afternoon time trials, night racing, and I wake up after the sun sets (no matter how long I have been up!) A natural born night owl here. Coffee, and a lot of it is my wakeup juice. So, experience tells me I am close, but get away from coffee as a prelude to class racing. It was killing me. Then I found a legal cure, as I stopped taking my coffee pot to the track, but then also too shell shocked from many E1 red-light, I swung the as bad opposite direction to .060-.098 greens that will not also win many rounds/races. Though a few more than leaving first reds will. Long story short, I finally found an easy (and legal), cure, and though it took a while, it took. Last race was Q1 .005, C1 was .012, E1 (still not yet fully convinced, I came up on the converter in E1, then before staging said nope, I backed off 200 rpm, staged and lazed out a .059 just to make sure it was not red), and banged off what I thought was my best run yet, followed by E2 .018, though both on the brakes at the big end I took just a bit too much stripe...OK, the car has been in the zone, though very slow at Vegas, very consistent when I am not attempting to push it the 3 tenths plus faster it is absolutely very capable of running, and just driving it the same, and the drivers head is finally out of his butt and in the game also, at the same time. Ok, let me take a pic of 6 time slips, and resize the pic and post it. All are at Las Vegas, altitude struggle bus track w/that lousy DA. 1 from E1 November 2023(cold out), 5 from April 2024 (98 Degrees out), pay no attention to R.T.'s I covered that already. Pay little attention to the final ET's 5 of the 6 were somehow on the brakes, a lil' or a lot, leading or following. 2 different shifters, many tiny or large changes, and a major class change and change back, all are either E1, E2, C1 competitive races. But, struggle or not, as a lifelong bracket racer ...7 thou between November 2023 E1, and April E1, and look at all the 1,000' ET's and MPH. The car has been in the game, the driver was just needing to catch up, and quit worrying about going fast. The super fat air, with the stock ECM/Power Module is doing its job, even if phat and rich as can be. The dial in's are not all equal. That is super perplexing to the guy who rarely ever faces anyone in his class and is a bracket racer at heart. I am going to, but would you touch that? Go ahead Billy, Yac, and anyone else...Yes, I need to laptop tap, tap tune. But, I am going to both document everything, every lil' thing I can first before we put that Holley EFI System it needs on it. It will be changed a lot before October. It is still hard to go that route when it can run that consistent in present form.
Gary Lucier - 7832 STK. / 7832 E.T. EF/S Slow Sled. I am, but a simple test of your true patience. So, do all the really "Big Wheelies" you can! Last edited by Cglrcng; 05-02-2024 at 09:33 AM. Reason: spelling |
Liked 49 Times in 26 Posts
...... more than a few called me Lucky!
Ah, but you truly are LUCKY to have an understanding family, and so many racing friends willing to assist and help you, and the opportunity to re-engage old friendships made along the way....not all of us are blessed that way.....Great story |
