Old 05-01-2024, 06:22 AM   #1
JeffM
Liked 5 Times in 5 Posts
Default Tilberg shortblock, Jesel, Bryant, Weld, Carillo, etc
Can bring to Bristol, and Division 3 races
Tilberg low compression 350 shortblock
Crower 5.7 rods 2.125 with .875 pins
BME pistons, total seal rings
Crower crankshaft
Crower 903 tie bar lifters with .810 wheels
comp cam
$6000.00
Jesel Dogbone lifters LFD-44002 – set of 16 – 1000.00
LS Bryant crankshaft – 4” stroke – 58x - $2800
Carillo rods 6.1 rods (was used with Bryant crankshaft above)
BE :2.2253
PE :0.9285
Length: 6.100
B Width : 0.938
$1200.00
Forged small journal 327 GM crankshaft. Offset ground (.020 under) by Shaftech. 1.979 rods, 2.300 mains – 3.263 stroke $750.00
Oliver I beam 5.7 rods set of 8 (was used with Shaftech crank above)
BE: 2.125
PE: 928
Length: 5.7
Weight each: 575 Grams
$800.00
ATI converter
Flashed 6500 behind 427/430 LS Combo – 8” Powerglide spline - $500
7" Converter - Dynamic. Powerglide input, flashed 7000 behind 327/275 hp combo. - $500.00
Wilson 1” 4 hole aluminum tapered spacer – Dominator flange PN 024110 - $150 used for test only
6.00 12 bolt ring and pinion. Ring gear has been backcut - less than 10 runs $250.00
Biondo RPM2 shift controller – 2 LCD bars are inactive, but still legible to program - $100
Polished fabricated valve covers with baffles tall - $100.00
Weld Alumastar 15 x 12 rear wheels (measure 12.5) with 4.75 pattern and 3” BS. $900.00. Very good condition, no screw holes
Precision Performance Products Kwik shift I manual shifter – excellent condition – no mounting plates. Black. 3 speed, push to shift with clean neutral. $350.00
TCI SBC/BBC lightweight 29.2 168T flexplate PN 399870LW, like new. Weighs 6.09lbs. Can barely see the contact patch on the starter ring. Original date was 1/19, but was only ran in the car for 2 races. Will need recertified. Excellent condition $300.00
Jesel 1.8 intake/1.6 exhaust sportsman aluminum lightened rocker arms. SBC 23 degree heads. Rockers and shafts are refurbished from Jesel in sealed bags never ran. Rocker stands and bolts are used. No rocker studs and hold down bolts $700.00.
Manley 221443P-16 valve springs with 23648-16 Ti - retainers, locks and 42573-16 locators (run on dyno) $300 for set.
ATI balancer pulley PN 916794 4 groove aluminum 6.430 diameter - New $40.00
ATI balancer pulley PN 916732 4 groove aluminum 6.430 diameter – used $50.00
CV products 3/8 pushrods (qty 18) 9.200 x .080 x 5/16 ends – used but good condition – $30.00
Trend 3/8 pushrods (qty 16) 7.450 x .135 x 5/16 ends – used but good condition) $50
Trend 7/16 tapered pushrods (qty 16) 9.400 x .165 x 5/16 ends new - $150
Trend 3/8 pushrods (qty 8) 9.400 x .135 x 5/16 ends used - $25
Trend 3/8 pushrods (qty 8) 9.450 x .135 x 5/16 ends used - $25
Trend (qty 17) – 9.150 DBL taper .135 wall pushrods 5/16 ends (used good) $35
Trend 9.400 DBL taper .135 wall pushrods 5/16 ends (11) new $150
Trend 9.300 DBL taper .135 wall pushrods 5/16 ends (11) new $150
JRI 2010-2015 Camaro front struts $500.00 used.
1 – Lingenfelter billet steel LS block girdle, No hardware $500
2 GM truck oil pans (1999-2006) pan only $50.00 each
260-223-0157
superstock@live.com
Jeff Myers
SS3254
S1522
JeffM is offline   Reply With Quote
Search this Thread:
Advanced Search
