Old 04-26-2024, 06:48 PM   #1
Jrh5220
Liked 29 Times in 18 Posts
Cool Re: 402 stocker engine
Originally Posted by SDT1DYI View Post
I would consider changing the Oil to Maxima break in Oil and then put a load on the motor in the car a couple of times, letting it cool down in-between and see if this changes the breather oil smoke condition.
Steve Teeter Stk/SS 620
How warm should the engine be? Before the shut down?
Jrh5220 is offline   Reply With Quote
Old 04-26-2024, 07:53 PM   #2
SDT1DYI
Liked 455 Times in 147 Posts
Default Re: 402 stocker engine
I assume it's an Automatic?
Get the motor up to 120-130 on jack stands. In gear , hold the brake , put it on the Convertor to load the motor maybe 5 6 seconds. 180- 190 temps cool it repete. Or take to the track and make 2 WOT hits.
Again, suggest that you use Maxima break in Oil.
Where is the timing set at? Locked out distributor advance? I would be very conservative with it. BB 402 Stocker start with 32 33 degrees go from there.
SDT1DYI is offline   Reply With Quote
Old 04-27-2024, 08:55 AM   #3
Ralph A Powell
Liked 225 Times in 136 Posts
When you doing all this have a blowby meter hook up to it. When we had our B-Dragster you could spin the starter and if the float moved in the tube there was blowby!
Old 06-04-2024, 11:49 PM   #4
Jrh5220
Have not had a blow by meter in 20 years.this is the only the 2 nd engine I had do these,one was many years ago . Sold it I have race bbc for
Longer than care to remember. These is one is been the worst. I have had it apart 4 times hone it each time with the same results. The engine seem to leak fairly well 2.5 to 3.7 warm. Ran 10.64 at 128.00
Old 06-05-2024, 09:07 AM   #5
Ralph A Powell
Leak down will only tell what?s going on at the top of the cylinder. Another easy test is when doing leak down is rock the piston at TDC let it go to BDC and pull the piston up with leak down tester still attached watch the meter as you pull up to TDC it takes a ratchet with extra long handle.
