#1 | |
Liked 520 Times in 176 Posts
I'm pretty confident if you can get your Main and Rod clearance's between .002 to .0025 you should be in a good zone. Running to 7500 rpm with 5/ 30 wt. oil 60 to 70 lbs. of oil pressure will also be safe. Have a good day, also have the crank magged for cracks before having any work done is also a good idea. Respectfully, Henry Kunz 1534 H/SA |
Liked 205 Times in 93 Posts
clevite H series bearings r a good thing too. be aware the H series rod bearings r marked for upper/lower orintation.
Liked 67 Times in 30 Posts
What Henry said is spot on, that’s exactly what I shoot
for clearance and pressure wise, things are happy there and will give good performance and longevity!
Ron Mattson 5015 STK |
I like 0.002" on the rods, and 0.0025" on the mains, and I prefer the King bearings. If you go higher than that on clearance, you probably need to use thicker oil, ie. 20W50.
Alan Roehrich 212A G/S |
Liked 20 Times in 15 Posts
thanks all for the help. funny to think back on how ideas used to be. you can just imagine the cam/dist gear milling away trying to turn an oil pump shimmed to pump 90 lbs.!!
Rod in AZ |
