#11 | |
Liked 114 Times in 29 Posts
#12 | |
Liked 189 Times in 48 Posts
The roof panels on this generation hard-top (1994-2002) Firebirds and Camaros are plastic / fiberglass from the factory and are glued on with an adhesive - they are not steel and never were - be careful with the assumptions..... They are also not easy to replace. That can happen to anybody, can we just hope that the guy's car is ok? I don't know if any aftermarket companies are making a repro but I do know they are not available from the factory nor have they been for a very long time. I tried finding one a few years ago and had no luck. The only option is to get one from a donor car and to get it off you have to use fishing line or piano wire, work it under the panel, and slice through the adhesive. It can't be peeled off with a putty knife.
Angelo DiTocco '98 Firebird SS/HA '98 Firebird B/SA Last edited by Angelo DiTocco; 04-07-2024 at 12:43 PM. |
#13 | |
Depending on the year, both the roof and sail panels are either thermoplastic or fiberglass and GM discontinued them years ago. When you go to the wrecking yard and try to remove them, it is worse than removing a windshield and they warp or get damaged. The OEM factory pieces were also defective and would bubble due to an issue with the epoxy and materials. The aftermarket replacements for both the roof and sail panels are either fiberglass or carbon fiber. |
#14 |
Liked 52 Times in 17 Posts
Angelo, I have a brand new one in the box along with all the components to switch from T-tops to solid roof.
Bernie Cunningham 7053 STK |
#15 |
Liked 226 Times in 97 Posts
Aside from the fact that this car wouldn’t be allowed in the Indy $10k race, they are planning to have this car on track next week in Vegas.
Tony Leonard S/ST 56 S/C 53 |
#16 | |
PM message me with your number and I'll give you a call
Angelo DiTocco '98 Firebird SS/HA '98 Firebird B/SA |
#17 |
Liked 148 Times in 54 Posts
If Robin Lawrence puts his car in the street version of 2013, just a switch of intake manifold, you'll see how dangerous a Naturally aspirated Coyote engine can be.
#18 | |
It's good to know NHRA Tech officials are still getting technical facts wrong. Consistency is good. |
#19 | |
Liked 57 Times in 20 Posts
Not sure I seen a carburetor from the factory in 2013... |
#20 |
Liked 1,861 Times in 434 Posts
Thanks Angelo I thought the roofs were steel
Why the dq
james perrone 1290 STK |
