Old 03-28-2024, 12:53 PM   #1
goinbroke2
Liked 393 Times in 153 Posts
Default Re: U/SA 302 ffffford build
Progress...once again, 1 step ahead and 2 back...
Got the batt all installed...and then looked at the blue 86lx in the driveway....the battery is supposed to be negative first as the front post is quite close to the hood..swap everything around...
ID:	69465   Click image for larger version
Old 03-28-2024, 12:57 PM   #2
goinbroke2
Then I found a smaller black cap to replace the big grey ugly one. (from a 75 international 304)
Not a "performance" thing, but it will "look older" lol!!
ID:	69467   Click image for larger version
ID:	69468   Click image for larger version
Old 03-28-2024, 12:59 PM   #3
goinbroke2
Tried bolting the hood scoop on and found I was missing some nuts and a stud. So instead of buying one, I made one on the milling machine.
Two different sized threads was fun.
Only took half an hour and it saved $.025!! LOL!!
Old 03-28-2024, 06:42 PM   #4
pmrphil
Liked 348 Times in 152 Posts
You're better off with the large diameter cap, spark goes where it's intended
Phil Molski
PMR Performance
S/C 1623
Old 03-28-2024, 09:42 PM   #5
goinbroke2
I'm running msd but really, I don't think spark scatter will be a problem. Worst case, I'll change it back. It was just a "looks" thing, won't stay if there is an issue but how much spark do you need for 200hp? LOL!!
Old 03-28-2024, 11:11 PM   #6
Liked 5,121 Times in 1,952 Posts
Are you afraid the alternator might overheat? ;-)
Old 03-31-2024, 12:45 PM   #7
goinbroke2
I'm a little slow Mark....can you elaborate?
Old 03-31-2024, 01:37 PM   #8
Stock pulley and fan on alternator..
