Old 03-16-2024, 01:07 PM   #1
Steve Grady
Steve Grady's Avatar
Liked 127 Times in 43 Posts
Default Re: flex plate expiry date tech inspection
When you have the case where you can photograph it and the SFI sticker card with your phone you can show tech the photos with the matching numbers. May be easier to keep track of while keeping the card with the stickers where it won't get lost.
Reid cases also have a Mfg Date and Serial number that is stamped on case and on the card the SFI stickers are on.
Originally Posted by 63corvette View Post
Reid has stopped installing the SFI stickers on the transmission cases in for recertification. They stamp the case with the numbers for the case and flex plate shield on the side of the case flange and include the stickers matching the case for the customer to use for tech purposes.
I carry my stickers in the trailer where I hope I can find them if asked to provide them.
Just my experience.
Rick Cates
Canyon, TX
Div 3 Sales, Service and Tech for many manufacturers
Steve Grady is offline   Reply With Quote
Old 03-21-2024, 04:33 PM   #2
63corvette
Liked 359 Times in 103 Posts
Directly from an un-named NHRA employee there is no plan to do inspections for sfi tag dates at the races unless there is found to be a reason or a need to do so on the flex plates.
The racer signs the tech card certification saying it is good and unless there is some reason to question that you are good.
It all falls back on the racer.
I feel sure there will continue to be staging lane spot checks for the easy and quick things to check.
Rick Cates
Canyon, TX
63corvette is offline   Reply With Quote
Old 03-21-2024, 06:13 PM   #3
Terry Cain
Terry Cain's Avatar
Liked 231 Times in 107 Posts
A lot easier to just check all the broken pieces laying on track after it comes a part.
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 04-28-2024, 12:02 PM   #4
John Dinkel
Liked 263 Times in 68 Posts
Angry Re: flex plate expiry date tech inspection
I removed my Mopar SFI flex plate 29.1 dated Dec 2002 and it looks like new. Sure seems like a lot of money to spend when they last so long.
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
Old 04-28-2024, 04:25 PM   #5
MR DERBY CITY
Liked 7,965 Times in 1,524 Posts
John, you can get a recert for $40 bucks …. Call me if interested …502-693-1735 …. You would send the flex plates to Ohio.
Old 07-17-2024, 02:08 PM   #6
Mike Gray
Mike Gray's Avatar
Liked 691 Times in 199 Posts
I purchased my flexplate (29.1) before they were mandatory and my car was stuck in paint. I finally got it put together and went to make some shake down runs at Bakersfield. Before going I was looking at the rule book and found the certification is only good for 3yr and the trans blanket only 2yr.! What the heck, I was out of certification without making a single run. How do these items wear out or become damaged, they should be a minimum of 5yrs. I think it’s the seat belt rule all over again.
Mike 7570 A/SA
