Liked 172 Times in 81 Posts
I've always been a fan of Aeroquip hose with their AQP inner tube but I would be surprised if it's still made in the USA. Aeroquip is owned by Danfoss, a Danish conglomerate who has manufacturing facilities all over the world. You also have to remember hose has a life no matter who makes it. I worked on heavy equipment before i retired and have seen hydraulic hose 10 years old that you couldn't bend and if you did, the inner liner would break up and come out in little pieces.
Jim Mantle U/V/SA 6632 |
Liked 920 Times in 259 Posts
I'm about to give up on the rubber liner stuff and go to the Teflon lined hose for everything.
Someone tell me a down side to it, other than cost. |
If you want a great braided hose designed for motorsports, that will not collapse, that is compatible with all fuels, retains, and does not permeate or leak fuel vapors, I recommend the Goodridge G-Line XF 811 hose. Due to having a full length Teflon liner, therefore, it requires the use of Goodridge fittings also.
Another option is using general aviation steel braided hoses that meet the requirements of MIL-H-83797 or FAA-TSO C53a, Type A such as Aeroquip 601/AE701 hose and it is compatible with AN and MS fittings. A good source for the Aeroquip hose are stores like Aircraft Spruce. Both of these hoses do not have a shelf life. There are some MIL-SPEC and SAE spec hoses that have a limited life of 10 years. |
#4 | |
Liked 115 Times in 35 Posts
Thanks for the info! |
#5 | |
