Liked 753 Times in 213 Posts
Now just for the fun of it, I play here with some “theoretical” numbers from his set-up.
The H/EA minimum weight is 1100 lbs with 8, 25 lbs per cu.in. giving us an engine of 134 cu.in. (utilizing the minimum weight) Index is 9, 56 sec. and Joshua Lee have a personal index of 9, 52 sec. He own the record at 8, 84 sec, (04/11/23) at 150 mph that is giving 0, 72 sec. under the index and 0, 68 under his personal index. You need 424, 63 H.P. (Wallace racing E.T and MPH calculator) to do it. (3, 17 H.P. per cu.in.) Now, let applied this set-up to the dragster class: L/DA. Minimum weight at 850 lbs and 7, 50 lbs per cu.in. Index is: 8, 85 sec. 134 cu.in. with 7, 50 lbs per cu.in., give 1005 lbs with 424, 63 H.P. (Wallace racing E.T and MPH calculator) give an E.T. of 7.77 seconds and 174.01 MPH. A whopping 1, 08 under!!! |
Liked 2,727 Times in 961 Posts
The Honda F20C is a great design and a great choice for Competition Eliminator.
#3 | |
Liked 79 Times in 22 Posts
Are you suggesting that he makes 3.17 HP/cid ? ***Nitro Joe's indicates that he has a 146 cid engine. 146 * 8.25 = 1205 lbs. min. wt. **** Last edited by Greenlight; 06-04-2024 at 11:31 PM. Reason: Update engine size |
If you use the Wallace racing E.T and MPH calculator...
at 146 cu.in. at 8,25 lbs/cu.in.=1205 lbs., you need 465,16 H.P. for his 8,84 record run. That give 3,186 H.P. per cu.in. http://www.wallaceracing.com/et-hp-mph.php |
Hi Greenlight, by the way`
I don't pretend that the Wallace racing E.T and MPH calculator algorithm is right on target. So my reason of the part text "Just for the fun of it". If you use the first tabloid on the Wallace racing E.T and MPH calculator and you introduce the weight 1205 lbs and the new calcul of 465,16 H.P., you will obtain and E.T. of 8,00 second. (So something is wrong somewhere) And at the end, if you use the old Moroso Power-speed calculator, you will obtain around 335-340 H.P. for his record time of 8,84 sec. at 1205 lbs. Definitively something to think... |
Liked 116 Times in 27 Posts
When I ran H/EA with my 171 CI Trail Blazer Engine, I went 8.64 @ 1400# @ VMP. Joshua Lee has a great combo for H/EA.
Richard Preiser 1613 FGT/I 1510 C/SA 161 F/DA Last edited by Rich67stang; 06-10-2024 at 03:16 PM. |
Very very good run with this set-up.
What is the base engine of your altered ? a 2,5 liters ecotec ? Last edited by Charles Stewart; 01-31-2025 at 06:12 PM. |
I sold the car to Matt Forbes (DIV 3), it is a 171 CI 2.8L, I believe they call it an Ecotec. I am a Ford guy. lol.
Richard Preiser 1613 FGT/I 1510 C/SA 161 F/DA |
