#1 | |
Liked 595 Times in 136 Posts
Whoever they were, I'll try to be polite and just say they were totally incorrect. Even the best cells in a batch from the best manufacturers are subject to the laws of thermodynamics and physics. If they are abused as described above, they will fail the same as any other. |
Guest
Posts: n/a
Jeff Gillette and I talked a while back about building a Steel transport vessel for lithium batteries. Maybe it’s time now.
I think it was 2021, the Lanes heading to Pomona had a battery fire in the trailer. Vette I believe and I think it was Lithium? Maybe they can confirm? Lithium’s aren’t in a great environment…. Last edited by Barry Polley; 03-05-2024 at 04:30 PM. |
I addressed the risks and use of Lithium batteries with NHRA in October 2016. Had a long phone conversation with Bruce Bachelder on the subject and he asked me to provide some technical information so he could share with others at NHRA, which I did a few days later. Of course, nothing came about it.
While still working at Boeing, I was part of the industry team as regards to the Lithium battery fires that took place on the Boeing 787 airplanes. As an outcome of the investigation, there were a lot of changes not only on the battery designs, but also on the provisions and installation. As an example, we ended designing, manufacturing, and installing a stainless steel box enclosure with a vent to the exterior of the fuselage for venting the fumes on all the 787 airplanes. SInce at the time there were already fires that had taken place at various tracks with Lithium batteries, especially people buying Chinese made cells on eBay and building their own, at the time I suggested consideration to requiring a metal enclosure for Lithium batteries. Unknown to me at the time was the number of events by various types of Lithium powered devices that had taken place since 1991 through 2016 on commercial flights, with Li-ion, Lithium-ion, Lithium Metal, Lithium Ion/Polymer, and Lithium Sulphur Dioxide batteries. Let's not forget the number of fires we see all the time on social media of EV's, including a cargo ship fire due to an EV. If I am going to err, I will err towards safety, especially when you have batteries sitting next to a fuel cell in most cars. Therefore, when I am asked about batteries, I recommend the LifeLine AGM racing batteries, or their Lithium Iron Phosphate battery that also has the BMS protection system. |
Liked 72 Times in 15 Posts
I have personnaly seen the aftermath of a old school lead acid battery that exploded when someone was trying to jump start a car in a gas station parking lot. I was a few feet away when it happened. I was not involved. I suspect the guy hooked up the cables wrong or the battery was defective.
Liked 24 Times in 11 Posts
I have also exploded a lead acid battery when an alternator died on my work truck and the clerk sold me an internal regulated alternator on a truck that had an exterior voltage regulator from the factory.....had to replace the fender on the truck and paint the other! big mess!
Liked 759 Times in 379 Posts
there are those that can break an anvil! Again, acid batteries typically don't go up in smoke resulting in fire and severe damage or loss of your car unlike Lithium batteries which is well documented!
FYI, I have been running a Braille Lithium battery which based on my research is currently the best option, in my dragster since last season. I made the swap strictly for the 40 lb. weight savings over the XS Power D1600 I had been running. ![]() ![]() Last edited by 1320racer; 03-08-2024 at 01:52 PM. |
Liked 3,193 Times in 975 Posts
Have the Lifeline Lithium Ion batteries in my RV, amazing how long they hold a charge and quickly you get them back up to 100%. BMS is a mandatory feature when you’re essentially sleeping right over them.
#8 | |
Liked 18 Times in 8 Posts
We actually put lithium batteries into the Corvette after the fire, a new Comp car we are building, and all of the electric race cars we've built. For those interested, check out Altronics Powerlite lithium batteries as they are incredibly light and reliable; the Battery Management System ensures they cannot overcharge or ignite. As for transporting lithium batteries.... that's a whole other issue when done in high volume, so I like where your head is at! Cody Lane |
Liked 55 Times in 26 Posts
They are very sensitive to temperature hot or cold.. and vibration, if voltage drops too low they can combust.. I feel like the risk outways the benefit...
