Old 03-05-2024, 11:58 AM   #1
Altronics
Sponsor
Altronics's Avatar
Liked 63 Times in 11 Posts
Default Re: Lithium battery goes up in smoke at Gainesville….
Most of the lithium batteries sold by this "Brand" in question do not have a BMS (Battery Management System)
The BMS protects the battery!!!!
Myself and Pat McCue (MLE racecars) have been in talks with the NHRA for a couple of years now trying to establish a requirement for all lithium batteries used at NHRA events have the correct protection built in. Hopefully, this will get finalized soon.
It is unfortunate that there are several companies that are selling lithium batteries in the performance market without a BMS or any other protection. Note: Internal battery "Balancers" are a BMS and are NOT protection!
It is much less expensive to build a lithium battery without a BMS. The BMS can double the price of the battery.
Many batteries will also advertise using Lithium Iron Phosphate - LiFePo4 "Safe" cells, and although they are the Safest lithium cell, they still can go into thermal runaway without a BMS.
I have 30 years engineering experience developing electronics. When Lithium batteries first started being used in the automotive aftermarket there were no BMS systems that could handle the power required to crank high compression racing engines. I spent many years developing the first BMS that could work is this application. The BMS used in our PowerLite PRO series batteries fully protects the battery from you and you from the battery. Our BMS protects from under/over voltage, cell imbalance, over/under temperature, cranking time limit, over current, and short circuit.
Here is a link for more basic info on a BMS->
https://en.wikipedia.org/wiki/Battery_management_system
Lithium batteries are great when built and used properly. We have PowerLite batteries that are 10 years old and still going strong and of course, at about 10 pounds, it is hard to beat the cost per weight savings.
Remember:
1) Balancers are NOT protection
2) There are no such thing as matched cells that do not require a BMS
3) There are no lithium battery chemistries that do not require a BMS
4) A Lithium battery without a BMS is not a good idea
Do your homework before purchasing a lithium battery. Make sure it has a Full BMS protection!!!
Feel free to contact me if you have any questions!
Fred Bartoli
847-923-0002
Altronics is offline   Reply With Quote
Old 03-05-2024, 01:14 PM   #2
Eric Merryfield
Eric Merryfield's Avatar
Liked 502 Times in 130 Posts
Remember:
Good info here, don't think you were referring to my little ATX 20HD which does have bms, I seem to recall one or two of the manufacturers I called up didn't use BMS. Their argument was it was a crutch for substandard cells, which I can see, but I wanted a bit more security with a BMS. Rapidly changing world, even Optima now offers small lithium orange batteries with BMS.
Eric Merryfield 1883 STK
Old 03-05-2024, 02:55 PM   #3
Dan Bennett
Liked 592 Times in 135 Posts
Whoever they were, I'll try to be polite and just say they were totally incorrect. Even the best cells in a batch from the best manufacturers are subject to the laws of thermodynamics and physics. If they are abused as described above, they will fail the same as any other.
Dan Bennett is offline   Reply With Quote
Old 03-05-2024, 04:27 PM   #4
Barry Polley
Guest
Posts: n/a
Jeff Gillette and I talked a while back about building a Steel transport vessel for lithium batteries. Maybe it’s time now.
I think it was 2021, the Lanes heading to Pomona had a battery fire in the trailer. Vette I believe and I think it was Lithium? Maybe they can confirm?
Lithium’s aren’t in a great environment….
Old 03-05-2024, 07:35 PM   #5
SSDiv6
Liked 1,580 Times in 582 Posts
I addressed the risks and use of Lithium batteries with NHRA in October 2016. Had a long phone conversation with Bruce Bachelder on the subject and he asked me to provide some technical information so he could share with others at NHRA, which I did a few days later. Of course, nothing came about it.
While still working at Boeing, I was part of the industry team as regards to the Lithium battery fires that took place on the Boeing 787 airplanes. As an outcome of the investigation, there were a lot of changes not only on the battery designs, but also on the provisions and installation.
As an example, we ended designing, manufacturing, and installing a stainless steel box enclosure with a vent to the exterior of the fuselage for venting the fumes on all the 787 airplanes. SInce at the time there were already fires that had taken place at various tracks with Lithium batteries, especially people buying Chinese made cells on eBay and building their own, at the time I suggested consideration to requiring a metal enclosure for Lithium batteries.
Unknown to me at the time was the number of events by various types of Lithium powered devices that had taken place since 1991 through 2016 on commercial flights, with Li-ion, Lithium-ion, Lithium Metal, Lithium Ion/Polymer, and Lithium Sulphur Dioxide batteries.
Let's not forget the number of fires we see all the time on social media of EV's, including a cargo ship fire due to an EV.
If I am going to err, I will err towards safety, especially when you have batteries sitting next to a fuel cell in most cars. Therefore, when I am asked about batteries, I recommend the LifeLine AGM racing batteries, or their Lithium Iron Phosphate battery that also has the BMS protection system.
ID:	69311   Click image for larger version
ID:	69312   Click image for larger version
Old 03-07-2024, 06:38 PM   #6
1legjerry
Liked 72 Times in 15 Posts
I have personnaly seen the aftermath of a old school lead acid battery that exploded when someone was trying to jump start a car in a gas station parking lot. I was a few feet away when it happened. I was not involved. I suspect the guy hooked up the cables wrong or the battery was defective.
1legjerry is offline   Reply With Quote
Old 03-07-2024, 07:53 PM   #7
jim reynolds
Liked 24 Times in 11 Posts
I have also exploded a lead acid battery when an alternator died on my work truck and the clerk sold me an internal regulated alternator on a truck that had an exterior voltage regulator from the factory.....had to replace the fender on the truck and paint the other! big mess!
jim reynolds is offline   Reply With Quote
Old 03-08-2024, 04:56 PM   #8
Cody Lane
Liked 18 Times in 8 Posts
It was an old lead-acid battery that we believe caused the issue.
We actually put lithium batteries into the Corvette after the fire, a new Comp car we are building, and all of the electric race cars we've built.
For those interested, check out Altronics Powerlite lithium batteries as they are incredibly light and reliable; the Battery Management System ensures they cannot overcharge or ignite.
As for transporting lithium batteries.... that's a whole other issue when done in high volume, so I like where your head is at!
Cody Lane
Cody Lane is offline   Reply With Quote
Old 03-11-2024, 08:53 AM   #9
FLEMING
Liked 54 Times in 25 Posts
They are very sensitive to temperature hot or cold.. and vibration, if voltage drops too low they can combust.. I feel like the risk outways the benefit...
FLEMING is offline   Reply With Quote
