Old 02-08-2024, 08:27 PM   #1
e vassar
Liked 271 Times in 107 Posts
Default Towing/Hitch questions
I have a 24ft enclosed trailer. I carry a 3100lb car,a scooter and a few tools.
I was towing with a Nissan Titan crew cab 1500 5.6 gas engine. It did pretty well but after installing air lift bags and a very heavy hitch with a torsion bar style anti sway system the truck would still take a dive when other vehicles would be about even with the rear of the trailer on the highway. I recently sent the Titan on its way,and bought a 2014 Silverado 2500HD Duramax. It is not a 4X4 but has the Z71 package so it sits up pretty high. I know I will need a drop hitch, and I don't mind using the one I have, but will I need to worry with these damn torsion bars to control sway?
Old 02-08-2024, 09:13 PM   #2
Mike Pearson
Mike Pearson's Avatar
Liked 1,916 Times in 574 Posts
Default Re: Towing/Hitch questions
The torsion bars are to distribute the weight not control sway. They do make sway control. I would continue to use the torsion bars.
Mike Pearson 2485 SS
Old 02-08-2024, 09:32 PM   #3
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
This is what you need and want, none better!
https://www.equalizerhitch.com/
Old 02-08-2024, 09:44 PM   #4
Kenney Kelley
Liked 72 Times in 36 Posts
[QUOTE=e vassar;693133]I have a 24ft enclosed trailer. I carry a 3100lb car,a scooter and a few tools.
I was towing with a Nissan Titan crew cab 1500 5.6 gas engine. It did pretty well but after installing air lift bags and a very heavy hitch with a torsion bar style anti sway system the truck would still take a dive when other vehicles would be about even with the rear of the trailer on the highway. I recently sent the Titan on its way,and bought a 2014 Silverado 2500HD Duramax. It is not a 4X4 but has the Z71 package so it sits up pretty high. I know I will need a drop hitch, and I don't mind using the one I have, but will I need to worry with these damn torsion bars to control sway?[/QUOTE
Mr Vassar What i would do first is put my race trailer on level ground and level the trailer and measure from the ground to the top of the trailer hitch where the ball goes. then i would do the same thing to the truck measure your existing hitch to see how much you are going to have to lower the ball on the truck hitch if it's within an inch or two I would say it's ok. and yes i would definitely use the Sway Bars they serve two purposes they keep your truck level and trailer level plus they keep your truck and trailer straight when you have cross winds and also when a semi comes by you. I use a Reese Hitch
Kenney Kelley
Kenney Kelley is offline   Reply With Quote
Old 02-08-2024, 10:46 PM   #5
e vassar
The one I have is a Husky. The torsion bars are slightly different, but otherwise same hitch.
Old 02-09-2024, 12:59 AM   #6
1700camaro
Liked 226 Times in 115 Posts
We use this one but had to buy a bigger drop for the shank. We pull with a 2023 3500 Duramax Dually & have a 34' Vintage bathroom package trailer.
Make sure you have your set-up according to the instructions & it covers your trailer tongue/gross weight.
https://proshop.summitracing.com/parts/CHT-17501
1700camaro is online now   Reply With Quote
Old 02-09-2024, 11:33 AM   #7
Steve Grady
Steve Grady's Avatar
Liked 101 Times in 40 Posts
A Reese "Dual Cam" sway control with a Reese weight distribution hitch to match your tow vehicle and trailer weight is a Very Good system to use when towing enclosed trailers.
Div 3 Sales, Service and Tech for many manufacturers
Steve Grady is offline   Reply With Quote
Old 02-09-2024, 11:44 AM   #8
curtis reed
Liked 125 Times in 59 Posts
Whatever you are using make sure the ball is rated higher than what you are towing. I see guys with a class 5 hitch then put a class 3 ball mount and ball in it.
You can get 7500lb 2 5/16" balls or 25,000lb. I only tow 6800lbs but have a forged ball mount that is rated at 17,000lbs and a 20,000lb rated ball. Be safe out there.
curtis reed is offline   Reply With Quote
Old 02-09-2024, 12:17 PM   #9
1320racer
1320racer's Avatar
no comparison to the equalizer hitch which is also made in America unlike the husky
Old 02-09-2024, 03:45 PM   #10
Mike Pearson
That system is superior to the old style with the chains for connections at the trailer. I have never seen that type. I have a gooseneck and a toter though.
