Go Back   CLASS RACER FORUM > Class Racer Tech > Garage Tech
Old 02-08-2024, 04:26 PM   #1
chevrolet
Default Q-jet problem
Have an 85 chevy 1 ton pickup with 454 and the q jet runs good but,,, it's always ben rich on idle .It will drive you out of the shop. Had the truck since new just never messed with it because dont know enough about them as far as rejecting them plus it runs good with it. Any one know of someplace I could get help with this thing. Its all stock.Ive rebuilt it a couple of times and done the little things I do know.Thanks Much...DR.
chevrolet is offline   Reply With Quote
Old 02-09-2024, 12:27 PM   #2
corky
corky's Avatar
Liked 4 Times in 4 Posts
Default Re: Q-jet problem
Find an old carb man and have the chock checked.
corky is offline   Reply With Quote
Old 02-10-2024, 09:26 PM   #3
You removed the idle mixture screw seals, right?
Old 02-11-2024, 06:12 AM   #4
Terry Cain
Terry Cain's Avatar
Liked 232 Times in 108 Posts
fuel leaking out jet well plugs.
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 02-11-2024, 02:23 PM   #5
That stopped in the late 60's with a different process to install and seal the plugs.
Old 02-24-2024, 12:11 PM   #6
REGGIE WINKLES
Liked 39 Times in 9 Posts
Mark is correct about the base plugs. The later Rochester Q-Jets don’t leak. Try leaning with it with the mixture screws. Also check for a “sunk” float.
Reggie Winkles 2650/Stock
REGGIE WINKLES is offline   Reply With Quote
Old 03-08-2024, 03:20 PM   #7
monte385
Liked 27 Times in 19 Posts
Are you sure it's rich & not lean? Eye burning is lean, if not just gassy could be rich.
monte385 is offline   Reply With Quote
Old 03-10-2024, 09:33 AM   #8
Henrys Toy
Liked 520 Times in 176 Posts
Smile Re: Q-jet problem
Good morning to all,
Maybe you just need to lean the Primary metering rods one or two numbers.
I'm sure the carb can't be that far off metering wise if you've owned this vehicle and someone else didn't get inside and "Fix " something? I'd get it apart and look at the number stamped on the rod, if it's a 41 try a 42 or 43 primary rod.
Does that carb have an Adjustable Part Throttle screw? You can try turning the screw clock wise in small increments and then drive the truck. You might want to check your ignition timing and get a vacuum gauge on this also and monitor what's going.
You've got a couple of things to look at, best of luck on your adventure.
Respectfully,
Henry Kunz 1534 H/SA
Henrys Toy is offline   Reply With Quote
Old 03-10-2024, 03:03 PM   #9
Mark Ruset
Mark Ruset's Avatar
Liked 43 Times in 29 Posts
It may be possible since you mentioned that the carb has been rebuilt a few times that the overhaul kit used may be incorrect. i would start with a new quality overhaul kit specifically. Designed for your year make and model. Try and locate a Delco overhaul kit. I had good luck using Quadrajetparts.com for all parts and gaskets.
Mark Ruset 2048 STK
Mark Ruset is offline   Reply With Quote
Old 03-10-2024, 03:24 PM   #10
monte385
Cliff has good parts too.
