Old 01-25-2024, 04:37 PM   #1
Jeff Niceswanger
Liked 1,032 Times in 368 Posts
Default Re: Ways to check on the use of illegal devices
Hi Billy. I think the original intention of that was so you didn't have to buy multiple sensors for each system.
Jeff Niceswanger 3740 SS
Old 01-25-2024, 06:21 PM   #2
Doug Hoven
Liked 861 Times in 165 Posts
The ARC module is already spelled out as being prohibited in Sportsman categories. I can’t imagine any sort of “traction control” being very consistent. Killing power, especially if trying to replicate a curve, may be too “stop and go” for it to work well in a bracket racing scenario.
1189 F/SA
Defunzalo Racing Enterprises
Old 01-25-2024, 06:48 PM   #3
DG
DG's Avatar
Liked 449 Times in 98 Posts
I have been around long enough to remember the old adage "your not cheating if you don't get caught". We all know its self certification on entries and cars rarely get looked at closely anymore. That said, I think the vast majority of racers do not intentionally cheat.
DG is offline   Reply With Quote
Old 01-25-2024, 08:12 PM   #4
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
you are very wrong
Old 01-26-2024, 09:20 AM   #5
Doug Hoven
Originally Posted by 1320racer View Post
you are very wrong
I see the flaw in my statement. I guess it really depends what is really defined as "traction control." I would put it into 2 categories, active, and passive traction control. I would consider time based timing retards to be passive. They are either programmed into the msd box, or the ecu. With these, the timing curve will be exactly the same every run, which has proven to be very consistent for many cars that use a setup like this. What I can't imagine to be super consistent would be a type of "active" traction control, where the msd or ecu is responding to wheel speed. I know that computers have come a long way, but the response time of something like this may not be quite fast enough for it to work with absolute accuracy. Correct me if I'm wrong, and I'm sure you will, but I've never heard of someone using an arc module or something similar that does the work of a "matty box" for you, and replicates runs with accuracy by changing the tune of the car going down the track.
1189 F/SA
Old 01-26-2024, 09:40 AM   #6
Frank Castros
Liked 2,727 Times in 961 Posts
Remember when it was about cutting a good light and running your dial? The only external wiring was for the Line Lock.
Old 01-26-2024, 09:45 AM   #7
Billy Nees
Liked 7,754 Times in 1,741 Posts
It COULD be that way again but I won't hold my breath waiting.
Billy Nees 1188 STK, SS
Old 01-26-2024, 10:41 AM   #8
1320racer
1320racer's Avatar
Doug, you're not going to hear of anyone using an ARC module in class or bracket racing because it is illegal.
That said, I have no first hand knowledge of the matty box and neither does anyone else that isn't/hasn't used it and they ain't talking about it no mind doing so on a forum but I am well aware of what can be done with the ARC module and if the question is can it be used for to make your car deadly consistent? That answer is YES and by deadly, I'm not talking hundreds, I telling you thousands from pass to pass but again, the best of the best bracket cars do this also without an ARC module.
start at 8:54
