Old 01-25-2024, 11:54 AM   #1
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: Ways to check on the use of illegal devices
Don, do you compete at BIG $ bracket races? We do and it's a non concern.
Old 01-25-2024, 12:14 PM   #2
Don Kennedy
Liked 904 Times in 237 Posts
I do not attend big$ bracket races but if i did I would make darn sure that my devices that are being used work ok as there is no rules at the races concerning devices ? or is there ?
Don Kennedy 7701 SS
Old 01-25-2024, 12:20 PM   #3
1320racer
1320racer's Avatar
Don, we do compete at the BIG $ bracket races, both locally and the Flings and I can tell you without doubt that no one that competes at these events cares if/what illegal devices maybe in use by some racers and the proof is that these races are typically sold out in less than 3 minutes! So all this talk about tree readers, down track position indicators, matty box, etc. is nothing but internet forum noise largely posted by racers like yourself that don't compete at these races. That said, running dead on, cutting .00x lights and taking a few thousands stripe is commonplace and no big deal in the year 2024.
That said, I do believe that ARC modules are being used by some with the Grid.
Old 01-25-2024, 02:37 PM   #4
Eric Merryfield
Eric Merryfield's Avatar
Liked 503 Times in 131 Posts
Having been to a Fling, those events are on another level.......and sell out because they are BEYOND well run......It ranks in my top ten for full event experiences......Along with Ken's classracer nationals, Tyler and Brians Class Racer Revival, many National Opens in canada, did one bracket race last year at Epping, wasn't concerned at all about illegal stuff, a lot of that stuff is a crutch at best at least in 1/8 mile.
For class racing 1/4 mile I would have an issue with spotters at top end.....The grid with ARC clearly is a no/no for actual class racing,
For non class racing and testing: I can see where it could add a function of safety and be a useful training, and testing tool, and would help keep someone from crashing, which is always bueno.
My guess is that 99% of any illegal activity in stock and superstock is under the hood and not to be found further down car........
Eric Merryfield 1883 STK
Old 01-25-2024, 03:24 PM   #5
1320racer
1320racer's Avatar
There is no rule prohibiting spotters
Old 01-25-2024, 03:28 PM   #6
DG
DG's Avatar
Liked 469 Times in 99 Posts
I had not heard of the ARC referenced above so I looked it up. For those that don't know what the MSD ARC linked with the Grid can do, this is from MSD's website:
"OVERVIEW
Now there is even more control with the PN 7761 module for the Power Grid System Controller. This module sets rpm limits based on slew rate (rpm acceleration) or based on time since launch. All of this is programmed seamlessly in MSD View.
The ARC module stands for Advanced RPM Control, it basically allows your race car to remain consistent, pass after pass, controlling your engines rpm curve during a pass. This helps you get down the track quicker and far more consistent. By using the MSD View software we can control the rpm down to a hundredth of a second and control the driveshaft speed for maximum traction. We can also pull out timing for a split second should we encounter tire slip. Set 3 different timing Retard curves and a Rev Limit Curve to control wheelspin."
Nice video explaining the system here:
Basically, it appears you set the driveshaft rpm curve in the Grid for a given ET, dial in and like magic you run within a hundreth of your dial in.
DG is offline   Reply With Quote
Old 01-25-2024, 03:34 PM   #7
Bob Bender
Bob Bender's Avatar
Liked 460 Times in 91 Posts
I know I will receive hate mail but, GET RID OF THE GRID in Stock
Bob Bender 144 O/SA
Old 01-25-2024, 03:56 PM   #8
Billy Nees
Liked 7,862 Times in 1,750 Posts
General Regulations; 8:3 and 9:2. It isn't legal the way that I read it.
Billy Nees 1188 STK, SS
Old 01-26-2024, 10:09 AM   #9
Mike Pearson
Mike Pearson's Avatar
Liked 1,958 Times in 593 Posts
"OVERVIEW
Dont feel bad. I had to look that up too. I had no idea what the ARC module did. I
guess I am old school. If I cant win without electronics or cheating then I dont get to. My deal is to cut a light and run the dial. I work real hard to do that. I am not a "hitter" but I do go some rounds and have finshed top 10 in the division 2 out of the past 4 seasons. I also had a divisional win in 22. Personally I dont think there is many out there cheating.
Mike Pearson 2485 SS
Old 01-26-2024, 11:17 AM   #10
Frank Castros
Liked 2,755 Times in 975 Posts
Someone is buying this module. I wonder how many MSD sells for $800.00?
