Old 05-14-2008, 08:36 PM   #1
Bob Verwold
Bob Verwold's Avatar
Default Re: Transbrake woes
Bill, Adjusting it the way you said I can't get it to work good in both holes it's either one or the other,( going from low to park ) so I tried to split the difference and that didn't work to good either. The bracket that mounts on the trans did move some that was when I took off the bracket and wielded two together put it back on readjusted it again. Seems to work for a period of time then WA LA I'm back in the dummy mode.Thanks for your help Bob.................
P.S. The bracket is mounted on trans.
Bob Verwold is offline   Reply With Quote
Old 05-14-2008, 08:57 PM   #2
Bill Baer
Bob
I think you have some missmatched parts, How did it work in low vs high?
Billy
Old 05-14-2008, 08:58 PM   #3
Bob Verwold
Didn't really try in low to drive
Old 05-14-2008, 09:04 PM   #4
Bill Baer
Bob
Try high, neutral, and reverse while your under there again the lever shouldn't move when the cable is removed. I suspect that the cable attachemt point on the lever is to far frm center and does not move the lever far enough in both directions.
Billy
Old 05-14-2008, 09:29 PM   #5
Bob Verwold
Bill you have an e mail
Old 05-14-2008, 09:32 PM   #6
Bill Baer
Bob
I'm currently at work you can e-mail me here: william.baer@exeloncorp.com
Billy
