Old 12-13-2023, 08:22 AM   #1
Jim Whitehead
Liked 150 Times in 41 Posts
Default Re: Weight break change
That’s not what happened here. My 85-86 Firebird 305 has two Hp options the weight breaks also changed in the other engine combo that did not get any Hp.
Jim Whitehead is offline   Reply With Quote
Old 12-13-2023, 09:26 AM   #2
Liked 10,714 Times in 2,230 Posts
If you think NHRA made an error ask you division Tech director to check on it. The class will change only with the HP on the OEM heads. With approved after market heads just the weight is adjusted up or down. Try doing the math yourself and see if you get the same result.
Check and see if the Camaro, same platform, and year model received the same treatment.
